    Over temperature shutdown on drivers 5 6
    • jeldem
      jeldem last edited by
      When I connect the new duetx2I have this message "Error: Short-to-ground on drivers 5 6, Error: Over temperature shutdown on drivers 5 6" . I don't use the stepper motor 5 and 6. just the servo output for the bltouch (It works well).
        It sounds like the status of those drivers isn't getting read properly by the Duet. This could indicate a faulty DueX2, a faulty interconnect cable, or just possibly a faulty Duet. Please check the following:
        • When you run M122, what status is shown for drivers 5 and 6?
        • Are the two stepper driver chips on the DueX2 cold or hot?
        • Turn the power off and check that the interconnect cable is securely plugged in to both connectors.
