    Calibration Cube XYZ is off, how to adjust Axis length
    1907
    • duetino
      duetino last edited by
      I have a Tevo Little monster and printed the testcube (https://www.thingiverse.com/thing:2145703), because all of my prints where not really fitting together. I know why now, since I never paid attention on how the WCS was aligned (on a delta it does not matter I thought)
      As i measured all the sides and get the following reading:
      X: 20.2
      Y: 19.99
      Z: 20.01
      As you can see the Y and Z Axis have an acceptable deviation, but X is far off limits.
      My Question is where and how can I feed some correction factors into the machine? gcode?
      do it to it -> rinse and repeat
        The easy way is https://duet3d.com/wiki/G-code#M579:_Scale_Cartesian_axes. But I suggest you measure a print larger than 20mm.
        • duetino
          Thank you I will print a upscaled hiphop uptodate cube to get accurate settings. Do you think that 100x100x100 is the right dimension?
          all the best
          • duetino
            Hi, thanks for the response and which leads me to the following questions:
            @dc42:
            … that that does not so directly apply on deltas or am I unright and the wiki does not know the duet3d controller?
            https://duet3d.com/wiki/G-code#M579:_Scale_Cartesian_axes here is says …
            But this does not work so easily for Delta and other RepRaps for which there is cross-talk between the axe
            please let me know before I print a monster cube 😉
            • fma
              fma last edited by
              I also noticed such deviation on X axis. I didn't dig yet, but is changing the scale the right answer?
              I mean, it can be an extrusion problem, so tuning scale on a 100x100 square won't fix the problem on a 20x20 square.
              So, I suggest you first try to see if it is really a scale problem, by printing a 100x100 square (100x100x2 cube, as you don't need to calibrate Z; even a 100x2x2 should be ok, if you only want to check X), and see if you get something like 101x100x2 (10% more on X).
              Frédéric
              • fma
                fma last edited by
                In fact, you can first try to measure the head move with a good ruler, without extruding. 10% of 200mm is 2mm, so easy to see.
                Frédéric
                • duetino
                  Hi, I'm talking about a tenth of a millimeter on X, which is way off, since Y and Z only have a hundredth deviation
                    M579 can be used to correct axis scaling on any type of printer. The "this does not work so well for a delta printer" bit refers to adjusting the tower steps/mm instead as described in the preceding sentence.
                    You should also check that the X and Y sides of a large cube or square are straight, not bowed inwards or outwards.
                    • fma
                      fma last edited by
                      Duetino, if your problem is really a scaling problem, when moving 200mm you should measure 202mm, which is easy to see. If you still have 0.2mm more, this means this is not a scaling problem! In this case, if you correct the scale for 20mm, a 200mm print will be something to 198.2mm…
                      So, first, move your axes as far as you can (200mm), and measure with a ruler.
                      Frédéric
