Duet 3 Mini 5+ WiFi V1.01 will only run with USB connected
Good day
My Rat Rig V-Core 3 using a Duet 3 Mini 5+ WiFi V1.01 failed mid test print and now will only run with USB connected .
I completed the 1hr long test print cube with the USB connected.
With the USB disconnected 5V & 3.3V LEDs are off, WiFi connection is lost.
24V PSU is good.
Some help with diagnosing the problem would be appreciated.....Thanks -
It sounds like the 5v regulator has failed.
Can you take a well lit close up photo of the board to see if we can notice any chip damage?
Do you notice any chips getting hot?
Have you checked the fuses? -
This post is deleted! -
Fuses are good
Some light discoloration on the PCB near the fuses.
Did not notice any burning smells during setup.
Thanks for your quick response... -
Have you pulled the fuses and checked them for continuity with a multimeter?
Both the 10A & 15A Fuses are good
Any test points on the PCB worth checking? -
If the 5v and 3v LEDs only light up when USB power is applied and not VIN and fuses are good then it's the regulator.
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
Will do ,Thanks for for your help.
