    Extruder control grayed out
    Duet Web Control
    312
    • Jasonpgrundefined
      Jasonpgr
      I can't use the extrusion control in the web control for some reason. It remains grayed out even though I have my extruder fully preheated to 235 degrees, but it stays gray and wont let me click on it. I'm so close to having this printer working again but this one has me stumped. I've even tried commenting out the 2nd extruder heater settings to bring it down to one heater and it still wont work. Suggestions? Here are my config settings.
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 22 2021 17:08:13 GMT-0700 (Pacific Daylight Time)
      M550 P"Dbot XL" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z1500.00 E420.00:420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z150.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z250.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1500 E800:800 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S60 ; Set idle timeout
      M208 X500 Y480 Z500 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop Inverted
      M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin ystop Inverted
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H5 F90 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-45 Y0 Z1.5 ; set Z probe trigger value, offset and trigger height
      M557 X45:450 Y15:420 S60 ; define mesh grid
      M307 H0 B0 R0.590 C256.5 D3.61 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S140 ; set temperature limit for heater 0 to 140C
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      ;M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
      ;M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      ;M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      ;M143 H2 S300 ; set temperature limit for heater 2 to 300C
      M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M563 P0 H1 F0 ; define tool 0
      ;M563 P1 D1 H2 F0 ; define tool 1
      ;G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      ;G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      alankilianundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @Jasonpgr
        @jasonpgr
        Can you send a photo of the DWC console?
        Did you select a tool? (I have a "T0" in my config.g)
        What version of firmware are you running?
        With V3.3 I run the hotend temp up, and at about 100C the Retract button becomes active and at about 150C the Extrude button becomes active.
        Here's my config.g (for a delta) if you want to look at stuff.
        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 09 2021 13:21:24 GMT-0500 (Eastern Standard Time)
        G90                                                     ; send absolute coordinates...
        M83                                                     ; ...but relative extruder moves
        M550 P"alan"                                            ; set printer name
        M665 R132.5 L291.06 B132.5 H400                         ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0                                           ; put your endstop adjustments here, or let auto calibration find them
        M552 P0.0.0.0 S1                                        ; enable network and acquire dynamic address via DHCP
        ; Testing external driver
        ;M569 P5 S1 T4:4:4:4                                     ; physical drive 5 goes forwards
        ;M584 X0 Y1 Z2 E3 U5                                     ; set drive mapping
        ;M350 X16 Y16 Z16 E16 U16 I1                             ; configure microstepping with interpolation
        ;M92 X100.00 Y100.00 Z100.00 U100.00 E91.00              ; set steps per mm
        ;M566 X1200.00 Y1200.00 Z1200.00 U1200 E1200.00          ; set maximum instantaneous speed changes (mm/min)
        ;M203 X18000.00 Y18000.00 Z18000.00 U18000E1200.00       ; set maximum speeds (mm/min)
        ;M201 X1000.00 Y1000.00 Z1000.00 U1000E1000.00           ; set accelerations (mm/s^2)
        ;M906 X1000 Y1000 Z1000 E800 U1000I30                    ; set motor currents (mA) and motor idle factor in per cent
        M584 X0 Y1 Z2 E3                                        ; set drive mapping
        M350 X16 Y16 Z16 E16 I1                                 ; configure microstepping with interpolation
        M92 X100.00 Y100.00 Z100.00 E91.00                      ; set steps per mm
        M566 X1200.00 Y1200.00 Z1200.00 E1200.00                ; set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z18000.00 E1200.00             ; set maximum speeds (mm/min)
        M201 X1000.00 Y1000.00 Z1000.00 E1000.00                ; set accelerations (mm/s^2)
        M906 X1000 Y1000 Z1000 E800 I30                         ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                                 ; Set idle timeout
        M208 Z0 S1                                              ; set minimum Z
        M574 X2 S1 P"xstop"                                     ; configure active-high endstop for high end on X via pin xstop
        M574 Y2 S1 P"ystop"                                     ; configure active-high endstop for high end on Y via pin ystop
        M574 Z2 S1 P"zstop"                                     ; configure active-high endstop for high end on Z via pin zstop
        M558 P1 C"zprobe.in" H5 F60000 T6000                    ; set Z probe type to unmodulated and the dive height + speeds
        G31 P500 X0 Y0 Z-0.1                                    ; set Z probe trigger value, offset and trigger height
        M557 R132 S20                                           ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T100000 B4388 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
        M307 H0 B1 S1.00                                        ; enable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                                 ; map heated bed to heater 0
        M143 H0 S120                                            ; set temperature limit for heater 0 to 120C
        M308 S1 P"e0temp" Y"thermistor" T100000 B4385           ; configure sensor 1 as thermistor on pin e0temp
        M950 H1 C"e0heat" T1                                    ; create nozzle heater output on e0heat and map it to sensor 1
        M307 H1 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S280                                            ; set temperature limit for heater 1 to 280C
        M950 F0 C"fan0" Q500                                    ; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1                                          ; set fan 0 value. Thermostatic control is turned off
        M106 P1 S0.7 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
        M563 P0 D0 H1 F0                                        ; define tool 0
        G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
        G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
        ; Custom settings
        M501                                                    ; Load config-overrides.g
        T0                                                      ; Select tool zero
        M575 P1 S1 B57600                                       ; enable support for PanelDue
        M912 P0 S3.5                                            ; MCU temperature calibration
        M591 D0 P3 C"e0_stop" S1                                ; Configure filament monitor
        Jasonpgrundefined 1 Reply Last reply Reply Quote 0
        • Jasonpgrundefined
          Jasonpgr @alankilian
          I have tool 0 clicked on.
          here is a picture of my firmware stuff from the web control page.
          alankilianundefined 1 Reply Last reply Reply Quote 0
            @jasonpgr I see "Status" = "Printing" What's going on there?
            Can you show us the status page?
              Phaedrux Moderator @Jasonpgr
              @jasonpgr said in Extruder control grayed out:
              Your M563 is missing a D0 to add a drive to the tool
              Jasonpgrundefined 1 Reply Last reply Reply Quote 1
              • Jasonpgrundefined
                Jasonpgr @Phaedrux
                as for the status, I was attempting a print when I took that screenshot to see if it would extrude under those conditions. Turns out thats a nope on that one. moved through all the motions, just no turning of the extruder motor.
                @phaedrux
                So just to clarify, in my config file where it reads
                it should actually read
                M563 P0 H1 F0 D0 ; define tool 0
                is that correct?
                  That's what I have in my config.g
                    is that correct?
                    Correct, assuming that your first defined extruder drive is intended to be used with T0
