    Invalid Height Map
    Duet Web Control
    808
    • Joeyhersheyundefined
      Joeyhershey
      Hello everyone,
      I am new to duet and im having some issues with getting the height map to work.
      I run the G29 and it completes it but i dont get anything on the height map other than it saying invalid height map.
      Can anyone help me with what to do to fix this??
      Thanks
      jay_s_ukundefined Joeyhersheyundefined 2 Replies Last reply Reply Quote 0
        Can you go to the system tab and delete the file called heightmap.csv?
        What version of firmware and DWC are you running?
          jay_s_uk @Joeyhershey
          @joeyhershey you're probably running DWC 3.2. Upgrade it
          flyeyesundefined 1 Reply Last reply Reply Quote 0
          • flyeyesundefined
            flyeyes @jay_s_uk
            @jay_s_uk said in Invalid Height Map:
            I’m having the same issue, running 3.3 RC2 on a duet 3 mini 5
            Can’t troubleshoot right now since my WiFi connectivity has been lost (another thread) but this will be on my todo list once I’m running again.
              Phaedrux Moderator @flyeyes
              @flyeyes said in Invalid Height Map:
              Update to 3.3 final.
                Joeyhershey @Joeyhershey
                @Phaedrux I am running firmware 3.3 and it show that DWC is 3.2.
                  You'll need to update the DWC files.
                  Upload this zip file to the system tab in DWC.
                  Joeyhersheyundefined 1 Reply Last reply Reply Quote 0
                    Joeyhershey @Phaedrux
                    @phaedrux yes i just did that and it works now. i was trying to update it yesterday and i think i did the wrong file and now i cant delete it. how can i get this out of the system tab??
                      That looks like a folder. You'll have to empty out the contents and then delete the folder itself. Or delete it from the SD card in a PC.
                        @phaedrux ok yea I just deleted everything in the folder and i still cant. ill do it through the PC.
                        Thanks for the help!! I'm new to duet and couldn't figure this out.
                          There may be files in there that aren't showing in DWC keeping it from being deleted.
                            @phaedrux ohhh ok that make since too.
