Trying my luck with a "flying" mount for Bondtech LGX Lite
So, aparently I have no elastic cord, So I can not test mount it. But, I thought that I would toss out a couple of photos to let "The hive mind" tell me what I haven't thought about.
I have a "first generation" Zesty nimble that is starting to missbehave. My initial plan was to use the LGX lite as a direct extruder, but I can not find a good geometry to fit the smart effector. So, flying extruder it will be for the time being.
On each carrier for the effector Ive put two mounts which fit abouve the nyloc that holds the mag ball, and then an additional m3 nut holds the mount.
Then a simple carrier which holds the effector.
Lastly a few pieces of elastic cord and some cable ties.
What do you think? Or rather... what have i NOT thought about?
@janjoh that should work fine.
i currently use a flying extruder on my predator.
my original predator used elastic cord to mount the extruder
