Closed Loop Motors SYNC problems
@jay_s_uk said in Closed Loop Motors SYNC problems:
@sozkan if you want to use the duet 3 boards you'll also need 1XD external boards as theres no way to connect external drivers to them
I would also suggest that that would make no difference to your current issueThank you for insisting on correct settings. By changing M569 P values like you said and T values like alankillian mentioned it worked perfectly.
But only extruder I kept P1 and T values the dyze design recommended T values. Because P5 it did not move at all.
Present values
M569 P1 S1 R1 T3:3:5:0 ; Extruder drive 0 goes Forward ;M569 P5 S1 R1 T3:3:5:0 ; Extruder drive 0 goes Forward ; extruder not running in this setup. M569 P6 S1 R0 T10:10:10:10 ; X:A drive 1 goes Forward M569 P7 S1 R0 T10:10:10:10 ; Y:B drive 2 goes Forward M569 P8 S1 R0 T10:10:10:10 ; Z:C physical drive 3 goes Forward -
@sozkan ok. what do you have for your extruder then? can you post the full info?
@sozkan you'll probably need to set that a bit higher too
can you provide the model number of the driver they provide? -
@sozkan how have you connected the expansion breakout board to the closed loop drivers? It might be that you may have the incorrect step polarity.
@dc42 said in Closed Loop Motors SYNC problems:
Actually now closed-loop drivers are fine and perfectly worked the first time with all of your support. Only the last one the extruder open-loop stepper motor different one having issues.
By the way connection of the closed-loop motor was mentioned before in this thread:
https://forum.duet3d.com/topic/18918/giant-delta-printer-slow-homing-issue/35 -
can you provide the model number of the driver they provide?I think the extruder driver Dyze design provide is :
http://www.szruitech.com/Detail Page R60.html
R60 two-phase stepper driver.it is Chinese so I relay on Dyze design documentations.
