    securly BLTouch deploed as Trigger
    bltouch deploed probe chrash
    • Topengaundefined
      Topenga
      is there a possiability to trigger the downwards movement of the Z-Axis until BLTouch niddle is in securly deployed and not before. Had this incident just twice during a long period but would like to ensure somehow that the nozzle is not chrashing into my bed. Alredy unscrewed the adjustment screw some turns but just to be safe on this side.
      Danijel
        I'm not sure what you mean. What gcode are you executing when it crashes?
        What is your dive height?
        Share your probe config line?
        Topengaundefined 1 Reply Last reply Reply Quote 0
        • Topengaundefined
          Topenga @Phaedrux
          @phaedrux
          Hello Phaedrux,
          this schould be just for safty reasons.
          The Z-Axis schould not punch downwards for Probing (BL-Touch) until the niddle of the BLTouch is not deployed....this is my wish.
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 08 2022 16:50:47 GMT+0100 (Mitteleuropäische Normalzeit)
          G91 ; relative positioning
          G1 H2 Z5 F2000 ; lift Z relative to current position
          G0 H1 X-405 Y-405 F4000 ; move quickly to X and Y axis endstops and stop there (first pass)
          G0 H2 X5 Y5 F6000 ; go back a few mm
          G0 H1 X-405 Y-405 F800 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolut position
          M401 P0 S1 ;Deploy probe
          G1 X35 Y60 F6000 ;move X/Y in Probin position
          ;G1 H1 Z-405 F1000 ; move Z down for first probe until the endstop is triggered
          ;G1 H2 Z5.085 ; lift Z Probe for second probe cycle
          ;G1 H1 Z-405 F100 ; move Z down for second and last probe until the endstop is triggered
          ;G90 ; absolute positioning
          ;G92 Z0.443 ; set Z position to axis minimum (you may want to adjust this)
          G30 ; home Z
          M402 ;retrec Probe
          G92 Z5.9
          ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 30 2021 05:49:28 GMT+0100 (Mitteleuropäische Normalzeit)
          ; BLTouch
          M558 P9 C"^zprobe.in" H2 R0.25 F150 T12000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X0 Y0 Z5.90 P25 ; set Z probe trigger value, offset and trigger height
          M557 X35:300 Y65:300 S15 ; define mesh grid
          ;M280 P0 S10 deploy
          ;M280 P0 S90 retrac
          ;M280 P0 S160 reset
          Is that somehow actionable?!?
          Many Thanks in advance and really WoW how fast you are reacting!!!
            Phaedrux Moderator @Topenga
            @topenga said in securly BLTouch deploed as Trigger:
            it's not necessary to manually deploy the probe pin. Perhaps this is your problem.
            M402 ;retrec Probe
            G92 Z5.9
            Same for retraction.
            And you probably don't want to use G92 to force a position if you're trying to use the probe to set Z0.
            You should calibrate the Z offset instead.
            https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
