Heater on 1LC stopped working - No VIN
Hi All,
my Hotend heater suddenly stopped working and I found out that there is no longer power on OUT0 on a 1LC v1.1 tool board. The 1LC (3.4-b7+1 since I'm using a PT1000) is connected to a Duet 3 6HC (RRF 3.4-b7).
Any ideas please?
; Hotend heater M308 S1 P"121.temp1" Y"pt1000" M950 H1 C"121.out0" T1 M307 H1 B0 S0.8 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; Set temperature limit for heater ; Tools M563 P0 S"Hotend" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z-2.15 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
@martinnyhc I assume that the 1LC board is working otherwise, so you know that it has VIN power.
When you say "No VIN", do you mean that you are not getting +VIN on the VIN side of the OUT0 connector? If so, then there is a direct trace on the underside of the PCB between the VIN connector and the OUT0 connector; so check the soldering of the OUT0 terminal block.
If the VIN pin of the OUT0 terminal block is at +VIN but the OUT0_NEG is not getting switched to ground, then that is different, and there are a few possibilities.
@dc42 that means that suddenly there is no power at all on OUT0.
FYI: just installed RRF 3.4.0beta7+4 and the heater is working again
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
