Solved Homing issues
Hello everyone.
I have a Duet Ethernet as well as a panel Due. I purchased this a few years back to build a printer I've yet to build however now I would like to connect it to my TronXY which has lost it's board. (Typical i3)
I think I have it updated, I went from 1.02 to 3.3. I'm trying to use the online config tool. I have a few issues still but I'll tackle them one at a time.
The machine won't home properly, I've tried changing the home files however it doesn't seem to respond to the changes.
If I press home X for example, the Z will move up a bit, the X axis will move about 10mm, then the Z will move back down. DWC will say that axis is homed even though it hasn't travelled to the endstop.
The X and Y endstops appear to be working, they light up the board when depressed and also seem to work during the fan test.I'm using the Ender 3 in the config tool as it is somewhat similar to my printer as a starting point.
I suppose I would be asked to upload the code, I'll have to go back and put a fresh one on there due to the changes I have made that may not make sense nor did they do anything.
Is there a special way to submit the code to this website so it shows up in a separate box like I see on other threads?
Thanks, al
@exwhyzee said in Homing issues:
code_text
Click on the </> button and then paste your code in the place of code_text
Thank you
Homeall.g
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Jan 13 2022 09:29:44 GMT-0500 (Eastern Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-240 Y-240 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-240 Y-240 F240 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X15 Y15 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
Homex.g
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Jan 13 2022 09:29:44 GMT-0500 (Eastern Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-240 F3000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F6000 ; go back a few mm G1 H1 X-240 F240 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
Please post your config.g as well and let us know where your endstops are physically located. What kind of endstops they are and how they are wired.
You can send M119 to see what the endstop status is when the switch is pressed or not. That will give an idea as well.
Can you also confirm that -x moves left, +x moves right, -y moves head to back of the bed, +y moves head to front of the bed.
@phaedrux said in Homing issues:
Thanks for your response, it's appreciated. The X endstop is located on the left, the Y endstop for the bed is at the back of the printer.
They are normally open and connected to the outside pins of the Xstop and Ystop on the Duet.-X moves the print head left, however -Y moves the bed back essentially moving the print head to the front of the bed. I suppose I'll have to switch the Y.
This is the result of M119 with the switch not pressed:
M119 Endstops - X: at min stop, Y: at min stop, Z: at min stop, Z probe: at min stop
With the endstops pressed:
M119 Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
Here is my config.g:
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Jan 13 2022 09:29:44 GMT-0500 (Eastern Standard Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"TronXY" ; set printer name M918 P1 E4 F2000000 ; configure direct-connect display ; Network M552 P192.168.2.1 S1 ; enable network and set IP address M553 P255.255.255.0 ; set netmask M554 P192.168.1.254 ; set gateway M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes backwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X235 Y235 Z260 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S150 ; set temperature limit for heater 0 to 150C M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S275 ; set temperature limit for heater 1 to 275C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory
no your config is correct. The Y endstop is at the low end as your print head is at the front of the bed.
Since your endstops are showing triggered when not pressed you will just need to invert the signal.
Change this
M574 X1 S1 P"xstop" M574 Y1 S1 P"ystop"
To this
M574 X1 S1 P"!xstop" M574 Y1 S1 P"!ystop"
Adding
to the pin name inverts the signal. -
@phaedrux That did it thanks!
I have a few other issues I'll attempt to resolve, I'll start a new thread if I cant!
