    berdair control issue, Cura or RRF ?
    110
    • MikeDC
      MikeDC last edited by
      I have a berdair set up on my duet3, and have set the frequency to Q500.
      for the printing I am currently doing i need minimal partcooling, mainly on bridges and support interfaces.
      i have set 0% - 5% cooling in cura.
      3 times during this print the berdair went crazy with 30% 60% and 100% fan
      inspecting the gcode generated by cura i think i have found the issue.
      2 of the lines pointed below.
      I know rrf will take fan control parameter S as either 0.0 - 1.0 or 1 - 255
      Cura is generating decimal places on all values above 0
      it looks like RRF cannot distinguish values lower than 1 from values above 1 generated by cura so when it sees 0.3 and 0.6 it set my berdair to 30% and 60%
      is there anyway to avoid this issue, any parameter to tell RRF which scale that we are using ?
        That's an interesting problem. I suppose it's pretty rare to use such low percentages. Will have DC42 take a look.
        One way to avoid it would be to just set cura to 1-5% and avoid the 0 range entirely. Would 1% cooling cause you issues?
        It also seems odd for Cura to use decimal values for the 1-255 range in the first place.
        What Cura version is it?
        resam MikeDC 2 Replies Last reply Reply Quote 0
        • resam
          resam @Phaedrux last edited by
          @phaedrux I think if you tell Cura to limit the cooling to a max of 5%, then this equals 255*0.05 = 12.75 as the highest numerical value passed to RRF. I think thats expected (at least I did).
          But that RRF flaps between thinking its a 0-1.0 and a 0-255 range is indeed problematic. Maybe we need a new setting to configure what the valid range should be, and to disable this "smart range detection".
          MikeDC 2 Replies Last reply Reply Quote 1
          • MikeDC
            MikeDC @resam last edited by MikeDC
            @resam
            this flap between scales has ruined a print for me 9 hours in with a not exactly cheap polycarb carbon fibre material 😞
            Im not a programmer but am trying to see if i can do a cura post processing plugin to repace any m106 commands less than S1.1 with S0 now
            resam 1 Reply Last reply Reply Quote 0
            • resam
              resam @MikeDC last edited by
              @mikedc you can also experiment with the M106 X parameter to set a max fan speed. https://duet3d.dozuki.com/Wiki/M106
              MikeDC 1 Reply Last reply Reply Quote 0
              • MikeDC
                @resam
                im already looking at this, and the min parameter
                i would have to change this max parameter any time i want very low airflow
                • MikeDC
                  MikeDC @Phaedrux last edited by MikeDC
                  @phaedrux
                  the cura version im using is 4.10.0
                  I have also posted this issue on the cura github, but i doubt they will do much about it.
                  there was a 3rd line in the code too where it set it to 1.0 which rrf saw as 100%
                  • MikeDC
                    @Phaedrux
                    I tried your suggestion, but set it to 1.1 not 1.0 as that would be 100%
                    also under experimental i set the bridge fan to 5%
                    look what happened
                    im using very low percentage as the berdair does push a lot of air for each 1% increment
                    rjenkinsgb 1 Reply Last reply Reply Quote 1
                      Is that S0.9 line from the first 4 layers where Cura would be scaling up the fan percentage as set by the Regular Fan Speed at Layer setting?
                      • MikeDC
                        @phaedrux
                        yes i think it is, i will play with a couple more models with some small layer areas which will triger minimum layer times and the fan speeds a bit more
                        • rjenkinsgb
                          rjenkinsgb @MikeDC last edited by
                          @mikedc
                          As an interim fix, could you connect an appropriate (adequate current) adjustable buck regulator module in the DC supply to the Berd-air PWM switch?
                          That should allow you to reduce the motor "100%" voltage, so requiring higher PWM drive for a given airflow, and allow higher min/max settings in the slicer, hopefully keeping it above 1%..
                          Robert J.
                          Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                          • MikeDC
                            MikeDC last edited by MikeDC
                            Ok, I got an answer that works for me 🙂
                            Im not a programmer but have been able to hack together a cura post processing plugin that seems to work fine for me.
                            I will attach it for anyone else should they experience the same issues.
                            Just drop it in the same folder as your cura post processing plugin scripts.
                            usual location
                            C:\Program Files\Ultimaker Cura 4.[xx.x] \plugins\PostProcessingPlugin\scripts
                            as a bonus it also makes my berdair more controllable, as it doesnt start turning until the S value is at least 26 and reaches max speed at 245'ish.
                            I can enter the berdairs start S value and Max S value and it now recalculates this as being the 0 - 100% fan range ansd also drops the decimal places by rounding
                            im also replacing any M107 with M106 S0
                            RRFFanScale.py
