Issues with PID Tuning (RRF 3.4.0-b7)
try firmware 3.4 beta 7+7
https://www.dropbox.com/sh/i5vox3xmkd55gaz/AAC19mI0WEC5GmEjLOBRbKs-a?dl=0
if you still have problems I help you in another way
3.4 beta7+7 - the results were even worse with PID
This post is deleted! -
then for the bed try to give this code in duet web control
M303 H0 S80 Y3
Y3= 3 hysteresis cycles
I have no PID issues with the bed.
The extruder PID calibration does not work for me when the parts cooling fan is included. Therefore I need to start the PID calibration as a heater and not as a tool.
The Rapido uses a different kind of heater which needs less power at higher temperatures. Maybe that is causing trouble for the PID calibration.
ok try this code to calibrate as a tool M303 T0 S205 Y3
undefined Phaedrux moved this topic from General Discussion
Y3 or Y5 produce the same PID results which cause issues. Only solution I have atm is to use the old PID calibration which does not include the fan.
then try to change these parameters:
I put my values try to use suitable values for you. you can find in config-override.g
try for example starting from your values to lower R and increase D
M307 H1 R2.762 D6.75
then put the string in duet web controll and press enter
digit M500 and press enter
make sure you have M501 at the end of config.g
ok the geometry and type of material affect the pid adjustment
undefined droftarts referenced this topic
