Issues with PID Tuning (RRF 3.4.0-b7)
Y3 or Y5 produce the same PID results which cause issues. Only solution I have atm is to use the old PID calibration which does not include the fan.
then try to change these parameters:
I put my values try to use suitable values for you. you can find in config-override.g
try for example starting from your values to lower R and increase D
M307 H1 R2.762 D6.75
then put the string in duet web controll and press enter
digit M500 and press enter
make sure you have M501 at the end of config.g
This post is deleted! -
ok the geometry and type of material affect the pid adjustment
undefined droftarts referenced this topic
