FYSETC 12864
Hi all,
So after a lot of struggle, I finally got the screen up and running (my other printer is running RRF; and not duet; so I used the script to get the screen up and running)....
I'm having difficulty controlling/using the encoder wheel. I am not able to completely switch between all menu items - it is a bit wonky - don't know how to describe it.
My script contains the following:
; ST7567 Init for FYSETC Mini12864 Panel V2.1
; Turn off backlight
m150 X2 R0 U0 B0 S3 F0
; Configure reset pin
M950 P2 C"PA.14"
; hardware reset of LCD
M42 P1 S0
G4 P500
M42 P1 S1
; Turn display on
M918 P2 C40 F2000000 E2
; Fade in backlight
while iterations < 256
m150 X2 R255 U255 B255 P{iterations} S1 F0
G4 P20
; flash Button 3 times
while iterations < 3
m150 X2 R255 U255 B255 P255 S1 F1
m150 X2 R0 U255 B0 P255 S2 F0
G4 P250
m150 X2 R0 U255 B0 P0 S2 F0
G4 P250
; Display "ready" button state
m150 X2 R255 U0 B0 P255 S2 F0I also don't know what to set in M950 P2 C"PA.14" --- as the duet uses a different naming convention. That refers to the 'configure reset pin' for the screen --- if I press the reset button, nothing happens.
Any help/guidance is appreciated!
Rgds
Tinus -
@reefwarrior the reset pin is different to the reset button. The reset pin basically resets the screen into a ready state whereas the reset button resets the board. Depends how you've wired the reset pin up I suppose.
Which board are you using this with? -
@jay_s_uk Hi! Using it with a duet2. What can be the issue with the encoder not being able to select an item?
@reefwarrior if you can't select anything, then you have an issue with your wiring to the Btn_Enc.
And then for PA.14 will be where ever you've wired the LCD_RST pin to -
EXP1.6 is wired to LCD.6
EXP2.6 is wired to LCD.3
EXP2.8 is wired to LCD.4EXP1 or EXP2
and then Duet's LCD row of plugs (next to SD) -
M918 P2 C40 F2000000 E2 causes the 'cursor' to jump all over if I turn one click back or forward. If I turn another click; it isn't flashing anymore; but I'm not able to select most of the stuff on the screen....
Anybody?
Try E1 as a first step?
Tried E1, E2, E3, E4, E10, E20. None of it works the way it is supposed to....
@oliof I will try a different screen and board this afternoon - luckily I do have spare.
@reefwarrior values of E1 to E4 (or E-1 to E-4) are expected and used. I have a FYSETC 12864 2.1 running on a Duet 3 mini 5+, with the following at the end of config.g
; enable display M918 P2 E-4 G4 S1 ; pause M918 P2 E-4 M150 X2 R255 U255 B255 S3 ; set all 3 LEDs to white -
@oliof Hi, tried. Different screen and different board. Same result.....
@oliof said in FYSETC 12864:
; enable display M918 P2 E-4 G4 S1 ; pause M918 P2 E-4 M150 X2 R255 U255 B255 S3 ; set all 3 LEDs to white Also I get the M150 command not supported.
CONFIRM the FYSETC mini12864 V2.1 is supported on Duet2 Wifi?
@reefwarrior X2 is not a valid command for standard RRF and its only valid on the STM port of RRF. Use X1
@jay_s_uk Even die x1 causes it to complain about the command. Been an uphill battle to get this screen to work...
@reefwarrior which firmware version? I think neopixel support was only added to the duet 2 in recent beta builds
@jay_s_uk Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3beta2 (2021-03-10)
@reefwarrior yea, you need to update
@jay_s_uk cool. Any specific version? Or just the latest BETA?
@reefwarrior I would probably go 3.4b6 or 3.4b7+4 from here https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-4-files/18
