    XXXL-printer
    • 3DDomiundefined
      3DDomi
      Hello All,
      I'm trying to build a large format printer.( XY =1500mm, Z = 1750mm). The printer will be completly ballscrew-driven. Mechanically it's almost done but I have problems with the motors. The Z-axe will be driven by a NEMA34 closed loop Motor and X and Y by NEMA23 Closed Loop Motors. I think A Duet can handle this but I have no experience with Duet. Can some one help me with the wiring? And can the RepRapFirmware handle without big changes.
      Thanks for helping me.
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @3DDomi
        @3ddomi
        THIS PAGE shows you how to connect external drivers to a Duet.
        The exact wiring is going to depend on the Duet you choose as well as the stepper motor drivers you select.
        The firmware will have no problems controlling three stepper motors.
