    How to save deviation??
    327
    • user M_123undefined
      user M_123
      Hii,
      How to save deviation? "in my case i am using G29 S3 P"heightmap.csv" but in heightmap.csv deviation is 0.00 ".
        I don't understand the question.
        If you load the saved heightmap in the DWC display, does it show it's values for deviation, etc?
        What firmware version?
        user M_123undefined 1 Reply Last reply Reply Quote 0
          user M_123 @Phaedrux
          @phaedrux no it's shows 0.0
          firmware version is 3.4b3
            Can you test with this 3.4 beta release?
            https://www.dropbox.com/sh/i5vox3xmkd55gaz/AAC19mI0WEC5GmEjLOBRbKs-a?dl=0
              @phaedrux no
              but why it's not save???
              • TWinklerundefined
                TWinkler
                The firmware may not allow you to save a file with the name "heightmap.csv" as that is the default name for the file created when you run G29 S0. Have you tried using a different name? You must also have a heightmap saved in your SD card already, which would have the filename "heightmap.csv" G29 S3 simply makes a copy of this file and renames it.
                  user M_123 @TWinkler
                  @twinkler my file name is heightmap1.csv
                  ok
                    Phaedrux Moderator @user M_123
                    @user-m_123 said in How to save deviation??:
                    @phaedrux no
                    It may be a bug, which is why I asked to test with the latest beta if possible. If it still exists in the latest code it might get fixed before it gets final release if it is a bug.
                      dc42 administrators @user M_123
                      @user-m_123 have you actually does a successful probing using G29 S0 to generate a height map, before you try to save it using G29 S2?
