    Dudes about Bltouch
    • peirofundefined
      peirof
      i am configuring Ratrig printer, and i have isues with Zprobe...
      Printer mounts a BlTouch, but when i order the printer Homing, X and Y axis are fine, but Z Duet send a message that are not z probe defined.
      When power on the printer, BlTouch do selftest, but when i send macros to deploy, retract and test, do nothing.
      a strange thing is that in config.g that Ratrig facilitates for the configuration, for the BLTouch it indicates that you put these lines...
      ; BLTouch
      M950 S0 C"io7.out"                     ; Create a servo pin on io7
      M558 P9 C"io7.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
      G31 P25 X-28.00 Y-13.00 Z0.90          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      But... Bltouch, its connected to io2
      Too add retractprobe.g and deployprobe.g
      ; deployprobe.g
      ; Called to deploy a physical Z probe
      M280 P0 S10															; Deploy the BLTouch pin
      and
      ; retractprobe.g
      ; Called to retract a physical Z probe
      M280 P0 S90													; Retract the BLTouch pin
      ideas, why not are detected when homing procedure?
      one thing more, after start printer and do selftest, BlTouch rest lighted
      fcwiltundefined Stephen6309undefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @peirof
        @peirof
        Are you using Duet v3 firmware?
        peirofundefined 1 Reply Last reply Reply Quote 0
        • Stephen6309undefined
          Stephen6309 @peirof
          @peirof Change the io7 in M558&M950 to the connections you have, io2.
          • peirofundefined
            peirof @fcwilt
            @fcwilt yes
