    Make more gcode file memory available
    Using Duet Controllers
    • RomeoFoxundefined
      RomeoFox
      on my Duet3D 6HC I need more free capacity for gcode files. I feel here are about 150 MB available on the original 16GB SD card via the web interface. How can I increase the space?
        jay_s_uk @RomeoFox
        @romeofox you're best off wiping the card and starting a fresh. Make sure you back everything up.
        Just copy your files off, format it to get the full 16 GB and then put your files back.
        The original card comes prepared for SBC mode so has a small boot partition and the rest setup for a pi.
        RomeoFoxundefined 1 Reply Last reply Reply Quote 1
        • RomeoFoxundefined
          RomeoFox @jay_s_uk
          @jay_s_uk
          That was exactly the problem. Thank you!
          How to create a new SD card can be found here: https://duet3d.dozuki.com/Wiki/SD_Card
          I also replaced the original Sandisk ultra with the faster extreme, which resulted in a significant jump in upload speed. It was worth it for that alone.
