    Using externa switches(buttons) with duet 2
    • martin7404undefined
      martin7404
      HI, all,
      After building 4 printers with Duet family of boards (wifi, duex, paneldue, duet 3 etc)
      I am planning to use duet wifi with external drivers for automatic drill operation for Alu extrusion 6 meters long . I wil repurpose old universal milling machine with the drill head
      I will control 2 axis
      -Z work feed for drilling using nema23 on the drill head to move about 60 mm in and out the part
      -X to move 400mm ( parts have 150,200 and 300mm step)
      2 set of pneumatic clamps , 1 set fixed and 1 set riding with the X axis
      This is ok and I know how to set it up
      The machine will also use panel due
      But I was wondering if and how I can use external switches, I will need at least two: START and STOP program
      I am not aware how to set this with DUET wifi
      Any Ideas?
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
        jay_s_uk @martin7404
        @martin7404 yes, you can do this. Just set them up as triggers using M581 https://duet3d.dozuki.com/Wiki/M581
        martin7404undefined 1 Reply Last reply Reply Quote 1
          martin7404 @jay_s_uk
          @jay_s_uk Ok , but how to make them Start command.
          The operator is not going to be qualified enough to use paneldue 😉 for starting JOB
            @martin7404 use M23 and M24 assuming its the same file over and over
              @jay_s_uk Ok I think I got this
              Thank you very much
              I still do not get how to set it that
              when trigger (START is pressed) ON to strat the program with M23
              I have to make a macro of some sort I think?
              P.S I see now trigger#.g
