    Layercalculation in WebIf - Madness
    • MoS-tekknix
      MoS-tekknix last edited by
      ]Hi,
      I've a problem which drives me nuts.
      In my End-Script i let run the Heatbed down to maximum (365mm). The WebInterface calculates this into the amount of layers which should be printed (here 1825 Layers).
      If i remove the G1-Command from my End-Script the calculation is right.
      Are there any chances how to deal with this?
      https://drive.google.com/open?id=0B39F2gM1VUvOUUFVUjl2WEVibTg
      Cheers
      MoS-tekknix
      • Motalw
        Motalw last edited by
        You can just use G90: Set to Absolute Positioning and then G1 Z365. it should work
        • MoS-tekknix
          Thanks,
          will give it a try
          • darookee
            darookee last edited by
            I use M98 in my before and after g-codes to run macros: [c]M98 P/sys/before_print.g[/c]. They don't get calculated into the layerheight…
            • MoS-tekknix
              With G90 there is no difference.
              My End-Script:
              [[language]]
              G1 E-2 F900  ;retract the filament a bit before lifting the nozzle
               to release some of the pressure
              M104 S0 ;extruder heater off
              M140 S0 ;heated bed heater off (if you have it)
              G90
              G1 Z365 E-2  F900 ;move Z down and retract filament even more
              G1 X-12 Y-10 ; Send X and Y Axis to Hom
              M84 ;steppers off
              M18
              M144
              WebIf shows:
              [[language]]
              Size:
              2.2 MiB
              Object Height:
              365 mm
              Layer Height:
              0.22 mm / 0.2 mm
              Filament Usage:
              19419.9 mm
              Generated by:
              Simplify3D(R) Version 4.0.0
              • Motalw
                what if you try to use G0 instead of G1?
                • MoS-tekknix
                  It make no difference if G0 or G1 it is Simplify3D which calculates the complete lines and notice also my LowerBed-Function.
                  Therefore, nothing what Duet or DWC is responsible for.
                  I go for the solution from darookee and use a Macro.
                  Cheers
                  MoS-tekknix
