    Dynamic settings / dampen vibrations
    • RomeoFoxundefined
      RomeoFox
      I'm trying to motivate my new Voron 2.4 350x350 to produce consistent print results. Unfortunately, I am struggling with massive oscillations exactly between 35 and 90 mm/sec. The trigger seems to be the excitation of the toothed belt (GT2) on the X-axis.
      Here my setup for the dynamic part:
      M566 X1500 Y1500 Z100 E2000 P1 ; set maximum instantaneous speed changes (mm/min)
      M203 X60000 Y60000 Z6000 E4000 ; set maximum speeds (mm/min)
      M201 X5000 Y5000 Z1500 E4000 ; set accelerations (mm/s^2)
      M593 p "zvd" F15 ; input shaping
      M572 D0 S0.03 ; pressure advance
      Are there any other controls in the software that I have overlooked?
      Gixxerfastundefined 1 Reply Last reply Reply Quote 0
      • rjenkinsgbundefined
        rjenkinsgb
        Try halving both the instantaneous speed change and acceleration values?
        They both seem rather high.
        Robert J.
        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
        • Gixxerfastundefined
          Gixxerfast @RomeoFox
          @romeofox FWIW, I have never seen a Voron 2.4 with a ZVD (resonance) frequency of 15Hz.
          It's pretty normal around early 60 Hz X and about late 40 Y unless something is loose.
          Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
          Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
          Ender 3 Pro with BTT SKR-2 + RRF
          • RomeoFoxundefined
            RomeoFox
            Thank you for the tips.
            I was finally able to locate the problem after days. It seems to be related to the "Cutting corners" function of the "SuperSlicer". I deactivated it and now the oscillations are back where they should be: approx. 46 Hz.
            But now all screws are really, really tight 🙄
            Now the
            M593 p "zvd" F46 ; input shaping
            is sufficient again.
            I also lowered the instantaneous speed change and acceleration values a bit. Here is still missing some fine tuning.
