    Bouncing Estimations in Print Progress
    Duet Web Control
    firmware
    532
    • infiniteloopundefined
      infiniteloop
      Can't explain these non-linear print time estimations:
      The pattern is consistent: either the value for filament usage or the estimation of file progress is way too high - the other one is too low. As the screenshots show, that interplay happened 4 times in just two minutes. At least, this behaviour is consistent with all print jobs, and the values in DWC are identical to those on my PanelDue.
      Hardware: Duet 2 WiFi, firmware: 3.4b7
        Is there anything notable about the print moves in those time periods?
        infiniteloopundefined 1 Reply Last reply Reply Quote 0
          infiniteloop @Phaedrux
          @phaedrux No. All 1250 layers ร  0.2 mm are identical, each takes about 1m15s, nothing special at all. With 2.05, that worked fine. Then I made the jump recently to 3.4b7, so I can't tell when the calculations might have been changed. However, I'm missing the incremental layer count in the state line of DWC, but I don't know if that is related to the phenomenon.
          • deckingmanundefined
            deckingman @infiniteloop
            @infiniteloop I've seen similar and remarked upon it on numerous occasions. It just seems to me that DWC takes a small snapshot in time of recent moves, rather than a wider perspective of the actual print progress. None of the estimations make any sense and I've given up on them completely.
              infiniteloop @deckingman
              @deckingman
              @deckingman said in Bouncing Estimations in Print Progress:
              Maybe, but with my special print object these snapshots should be very precise, as all layers take the same time to print - which makes manual calculation easy: <time_per_layer> * <remaining_layer_count>. However, with 2.05, the estimations of the firmware were better in a sense of "more linear".
                @infiniteloop I have a feeling that it all went haywire about the time that they ditched the estimation based on layer time. I was in the minority who found that one was marginally more useful than the other estimations, which are about as much use as an ashtray on a motor bike.
                Phaedruxundefined 1 Reply Last reply Reply Quote 1
                • Phaedruxundefined Phaedrux moved this topic from Using Duet Controllers
                  Phaedrux Moderator @deckingman
                  ๐Ÿ‘Œ Beautiful.
                  @chrishamm would have to comment on the current estimates.
                    @phaedrux said in Bouncing Estimations in Print Progress:
                    Hm, really? The estimation values on the Paneldue are identical, so I suppose they originate from the firmware. Or am I wrong (as so often๐Ÿค•)?
