    firmware 3.3
    • BlitzRegundefined
      BlitzReg
      Hi, after updating my firmware from 2.05 to 3.3 my duet wifi board will not home. I get an error the g28 failed to enable endstops. my printer was working just fine until the update. I did get an error that my G1 S is obsolite and need to use H. But even fixing that I still can't home. When I hit home all the z axis drops a step or 2 every time I hit the home all. Any help would be great! Thanks, Larry
      alankilianundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave
        Have you updated your config.g? There are many important changes from RRF2 to RRF3!
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        • alankilianundefined
          alankilian @BlitzReg
          @blitzreg
          Have you gone through the conversion process step-by-step and completed each successfully?
          CONVERSION.
            dc42 administrators @BlitzReg
            @blitzreg please check your M574 endstop configuration in config.g carefully. In particular, if your endstops are active low (e.g. normally-open switches) then the way you specify inverted endstop operation in the M574 commands has changed between RRF 2.x and 3.x.
