    Macro Can't open 0:/sys/0 to read, error code 1 ( Solved)
    Firmware installation
    • claustro
      claustro last edited by
      I put a file named SetNetworks
      in /macros
      the file contains
      [c]M552 S0
      G4 P1000
      M587 S"CasaBisi" P"binbin1973" I192.168.0.104 [/c]
      I execute throug repetier
      M98 P/macros/SetNetwork
      and the answer is
      23:04:18.698 : Can't open 0:/sys/0 to read, error code 1
      23:04:18.698 : Macro file 0 not found.
      23:04:18.698 : ok
      Now I am stuck
      I tried calling other macros without succes but M503 works.
      Tested other sd card with same results.
      My folder structure is
      gocdes
      macros โ€“hereI placed SetNetwork
      sys
      www
      Any idea what I am missing?
        Perhaps Repetier is failing to send the M98 command exactly as you sent it. Try using another program, such as Pronterface or a terminal emulator.
        • claustro
          Thank you , you answered at the same time I am going to post the solution ๐Ÿ™‚
          You are right repetier can't handle M98 correctly , solved using simplify3d console.
          Lightning answer anyway ๐Ÿ™‚
          thank you
          • claustro
            Connected but I am receiving this error, what this mean?
            Can't open 0:/sys/oem.json to read, error code 4
            Also I am on 1.19.2 running on Duet WiFi 1.0
            My corexy axis is screwed my last functionally config was
            [c]M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it)
            M569 P1 S0 ; Drive 1 goes forwards. (Change if motor goes wrong way. Or just turn the motor connection 180 degrees around..)
            M569 P4 S1 ; Drive 4 goes forwards
            M574 X1 Y2 Z0 S0 ; set endstop configuration (X1 is at MIN end. Y2 is at MAX end. (active high switch = S1, active low switch= S0)
            M667 S1 ; set CoreXY mode[/c]
            can you suggest me how can change it?
            • number40fan
              number40fan last edited by
              Read the notes. Have to swap connectors.
              • claustro
                thank you , I read it , but I prefer to change the config setting instead of swapping connector ,and I didn't remember the drive order , then I found that Y is number 1
                so
                M569 P1 S1 fix the problem.
                thank you for answering me.
                Andrea
