    Magnetic Filament Sensor - Firmware Update Error
    Filament Monitor
    • Shotfireundefined
      Shotfire
      My sensor is on version 2 and I'm trying to update to version 3
      Using latest github download 44a
      And, since it successfully erased the chip it won't work at all now
      Probably something simple I'm missing but when I try to update the firmware I get this error with or without the ":e" at the end
      V1.7 sensor , Adafruit USBtinyISP
      ***avrdude -p t44 -c usbtiny -U flash:w:FilamentSensor.elf
      avrdude: AVR device initialized and ready to accept instructions
      Reading | ################################################## | 100% 0.02s
      avrdude: Device signature = 0x1e9207
      avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
      To disable this feature, specify the -D option.
      avrdude: erasing chip
      avrdude: reading input file "FilamentSensor.elf"
      avrdude: input file FilamentSensor.elf auto detected as invalid format
      avrdude: invalid input file format: -1
      avrdude: write to file 'FilamentSensor.elf' failed
      avrdude: safemode: Fuses OK
      avrdude done. Thank you.***
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @Shotfire
        @shotfire It's been a while for me, but doesn't avrdude take HEX files which are produced by objcopy or something like that?
        • Shotfireundefined
          Shotfire
          Not sure, I was just following the command line in the WiKi
            @shotfire Oh I see it's documented HERE.
            Well, I'm not sure then.
            Here's what I get when I download from Release-44a: Does it match your binary?
            kilian@AlanDesktop ~/Downloads
            $ file FilamentSensor.elf
            FilamentSensor.elf: ELF 32-bit LSB executable, Atmel AVR 8-bit, version 1 (SYSV), statically linked, with debug_info, not stripped
            $ ls -l FilamentSensor.elf
            -rwx------+ 1 kilian None 32364 Feb  5 15:19 FilamentSensor.elf
            • Shotfireundefined
              Shotfire
              @alankilian I'm on Windows 10 so I'm not sure how to reproduce what your getting from Linux, on Windows it does show it as a 32kb file
                @shotfire Use the dir command
                02/05/2022  03:19 PM            32,364 FilamentSensor.elf
                Anyway, it looks like you've got the same file I got, so I'm stumped.
                Someone will jump in and help soon I bet.
                Shotfireundefined 1 Reply Last reply Reply Quote 1
                • Shotfireundefined
                  Shotfire @alankilian
                  @alankilian Switched over to a Linux machine running POP_OS and it flashed ok, shows V4 for the version
                  • Shotfireundefined Shotfire marked this topic as a question
                  • Shotfireundefined Shotfire has marked this topic as solved
