    Incompatible Firmware
    Using Duet Controllers
    • Xavierundefined
      Xavier
      I had to do a clean install on a new SD card, I previously had the Duet3 working with a Pi 4B absolutely fine, however now in DWC it stays at "Status: Starting", doesn't seem to detect my config, probably because it is not starting correctly, and in the diagnostics it looks like I have an incompatible firmware, I have tried updating everything as per the documentation, Pi should be updated fine using the latest DuetPi and then updated just in case, the duet firmware shouldn't have changed, as it was working previously, though I ran the update on that too. What am I missing?
      I get this on startup:
      Warning: Incompatible firmware, please upgrade as soon as possible
      Connection interrupted, attempting to reconnect...
      DCS has been stopped
      • Xavierundefined
        Xavier
        Diagnostics below:
        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-03b3
        M122
        RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0 running on Duet 3 MB6HC
        Board ID: 08DJM-956L2-G43S8-6J9F0-3SN6Q-9U0YG
        Used output buffers: 1 of 32 (4 max)
        (can't show the rest or it flags the message as spam 🙄 )
        chrishammundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
        • chrishammundefined
          chrishamm administrators @Xavier
          @xavier Try to run M997 from the G-code console to upgrade to the matching firmware. If it doesn't work, try pressing the reset button on the Duet when the board is in "Starting" state.
          Duet software engineer
          Xavierundefined 1 Reply Last reply Reply Quote 0
            jay_s_uk @Xavier
            @xavier that's an old firmware. I suggest updating the firmware. That's probably why it doesn't work.
            You may need to use bossa with it being an old build. But try the normal methods first (although you won't be able to do it through DWC with an SBC)
            • Xavierundefined
              Xavier @jay_s_uk
              @jay_s_uk the firmware was updated back in the day as it was one of the early cards. Odd that it would now be out of date, maybe it was reset somehow? The commands don't work so maybe I need to do it manually again...?
              Cheers,
              Xavier
              • Xavierundefined
                Xavier @chrishamm
                @chrishamm pressing the button while it is on?
                Thanks for the help!
                Xavier
