Issues with CAN bus on 6hc and 3hc / 1lc
I've been working on my build for a bit. I have the 6hc control board + a 1lc and 3hc connecting via can bus.
Initially over usb on the bench I was getting general connectivity from the tool board, could read voltage and run a stepper. I was having some issues and shelved that for a bit - wanted to get everything mounted, cables run etc.
I am now no longer seeing anything on the can bus. With only the 1lc ( and resistor in place on wire ) and the 6hc - no connectivity. Ditto with the 3hc ( only ) connected and with the jumpers on.
Full output from M122.
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-9P63L-DJ3S0-7JTDA-3SS6N-KBLRB Used output buffers: 1 of 40 (11 max) === RTOS === Static ram: 150904 Dynamic ram: 62964 of which 24 recycled Never used RAM 140300, free system stack 200 words Tasks: SENSORS(delaying,0.0%,102) SBC(resourceWait:,5.4%,346) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.0%,740) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.1%,93) MAIN(running,85.6%,967) IDLE(ready,1.8%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:11:06 ago, cause: reset button Last software reset at 2022-02-06 12:04, reason: User, none spinning, available RAM 140560, slot 2 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 681 MCU temperature: min 37.5, current 39.0, max 48.0 Supply voltage: min 0.3, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 0.1, current 12.1, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, reads 41610, writes 11 timeouts 0, SG min/max 0/0 Driver 1: position 0, standstill, reads 41610, writes 11 timeouts 0, SG min/max 0/0 Driver 2: position 0, standstill, reads 41610, writes 11 timeouts 0, SG min/max 0/0 Driver 3: position 0, standstill, reads 41610, writes 11 timeouts 0, SG min/max 0/0 Driver 4: position 0, standstill, reads 41611, writes 11 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 41611, writes 11 timeouts 0, SG min/max 0/0 Date/time: 2022-02-06 21:33:30 Slowest loop: 0.46ms; fastest: 0.04ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 8222, received 3, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 13363, free buffers 49 (min 48), ts 3333/3148/0 Tx timeouts 0,0,184,13,0,94 last cancelled message type 30 dest 127 === SBC interface === State: 4, failed transfers: 0, checksum errors: 0 Last transfer: 1ms ago RX/TX seq numbers: 17441/23552 SPI underruns 0, overruns 0 Disconnects: 2, timeouts: 0, IAP RAM available 0x2c83c Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.3.0 Code buffer space: 4096 Configured SPI speed: 8000000Hz Full transfers per second: 35.61, max wait times: 2.8ms/0.0ms Codes per second: 0.00 Maximum length of RX/TX data transfers: 3404/32
All have been recently purchased ( last few months ). I'm able to move my x/y/z from the 6hc no problem. Read temps etc - just nothing on the boards via can bus.
Error: M115: Response timeout: CAN addr 1, req type 6024, RID=14
M409 K”boards” { "key": "", "flags": "", "result": { "boards": [ {}, {} ], "directories": {}, "fans": [ null, null, {}, null, {}, {}, null, {} ], "global": {}, "heat": {}, "inputs": [ {}, {}, {}, {}, {}, {}, {}, {}, {}, {}, {}, {} ], "job": {}, "limits": {}, "move": {}, "network": {}, "sensors": {}, "seqs": {}, "spindles": [ {}, {} ], "state": {}, "tools": [ {} ], "volumes": [ {} ] } }
@bilsch
So just to confirm, when you had it on the “bench” you had working CAN? Or you just had the main board running over USB power?When everything is powered up are the status LEDs on all three boards blinking in time with one another?
How is the 1lc wired up? Is it the last board in the chain?
Which revision of the 1lc did you purchase? -
@alex-cr When I was using it on the bench I was drawing from usb + I added a 12v to the 6hc and other boards ( could pull many amps if I needed but never did )
I see on the 3hc or 1lc board a single blink followed shortly by 4 which I believe means its not happy about something
I found https://forum.duet3d.com/topic/17928/duet-3-expansion-3hc-v1-0-no-can-connection/3 which seems to show the same symptoms so going to read over that thread
Ok, issue solved wow!
So I probably missed it but getting the Duet2and3Firmware-3.3.zip and uploading it via the web interface put the firmware files in place. Once I followed the other forum article and got that hooked up - its working just fine! ( well, 3hc is still need to hit the 1lc )
yea confirmed the tool board just loaded up
Ok, noted new flow! Sorry for the wild excursion there!
@bilsch I'm glad you solved it.
