Solved Closed loop SH-CL57BH + 60HS2125-4004A working setup
*UPDATE on wiring
After some time and some positional errors in 2 weeks work, the problem was solved with new wiring
ENA+ and - are not connected , so as soon power ON, the stepper is enabled
DIR+ and Step + are conectod to +5V on expansion board , and DIR- and Step - on the DIR- and Step - on duet expansion boardSo after looking a for setup in number of threads I managed to run SH-CL57BH driver + 60HS2125-4004A stepper with duet wifi + breakout board.
Direct diferential from breackout board works great
- Setup I used this thread link text
M569 P6 S0 R1 T5:2.5:5:7.5 ; M584 Z6 ; M92 Z171.00 ; set steps per mm M566 Z60.00 ; set maximum instantaneous speed changes (mm/min) M203 Z3600.00 ; set maximum speeds (mm/min) M201 Z100.00 ; set accelerations (mm/s^2) M906 Z1000 I30
