SD card reader not working
Hi Duet pros,
I was installing a new Duet3 mini 5+ wifi. I couldn't connect to the DWC or update the firmware normally. I was able to update to R3.3 over USB, but I still couldn't connect to the DWC, I got a 404 error and I was told I needed to make sure the correct file were in the www folder. I did that. No change. I made sure all the correct files were on the SD card in the correct structure and I tried to update the main firmware again using M997 S0. It said it couldn't find the files. I tried to update the wifi server using M997 S1 - same response. I checked the damn card again. It was correct.
Connected over USB again and ran M122 and no SD card was detected. I did not plug-in an SD card extender or anything. Only the SD card that came with the board. But, maybe it's a bad card, tho it works fine on my PC? I reformatted via the instructions on the DUET knowledgebase, I even used the SD card formatting software that was recommended. Loaded the files back on. No SD card was not detected.
I tried another Sandisk SD card that was in use on another Duet board. That card was not detected. Reformatted that one just in case. No change.
So, anything else I can try or are we pretty sure the SD card socket is bad?
TIA -
@guysnover post the output of m122 please
"SD card 0 detected, interface speed: 0.2MBytes/sec"
M115
FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-06-15 21:46:20
ok
M122
RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: PZ4TZ-6296U-D65J0-40KMD-3513Z-7K44Q
Used output buffers: 1 of 40 (1 max)
Static ram: 102724
Dynamic ram: 104600 of which 464 recycled
Never used RAM 35916, free system stack 170 words
Tasks: NETWORK(ready,5.9%,520) HEAT(delaying,0.0%,420) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,0.0%,124) MAIN(running,80.1%,611) IDLE(ready,13.1%,29) AIN(delaying,0.8%,274), total 100.0%
Owned mutexes: USB(MAIN)
Last reset 00:00:43 ago, cause: power up
Last software reset details not available
Error status: 0x00
MCU revision 3, ADC conversions started 43394, completed 43394, timed out 0, errs 0
Step timer max interval 530
MCU temperature: min 20.4, current 21.7, max 21.9
Supply voltage: min 2.3, current 2.6, max 2.7, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Cache data hit count 86505699
Slowest loop: 0.32ms; fastest: 0.11ms
=== Storage ===
Free file entries: 10
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = -1 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== CAN ===
Messages queued 216, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 216/0/0
Tx timeouts 0,0,215,0,0,0 last cancelled message type 30 dest 127=== Network ===
Slowest loop: 0.18ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is disabled
WiFi module is disabled
Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
ok
- WiFi -
@guysnover when and where did you purchase the duet 3 mini?
@Phaedrux -
Feb 2nd, 2022. Spool3d.ca
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@phaedrux Thanks!
