    M915 won´t accept R2 or R3
    Beta Firmware
    657
    • vali3dundefined
      vali3d
      I have problems getting the crash detection to work again. Since upgrading to any of the 3.4 versions the crash detection won´t trigger (see https://forum.duet3d.com/topic/26051/3-4-0-beta6-crash-detection-problems). Recently I noticed that the M915 command does not accept an R2 or R3, which might be the cause of the problems. The configuration with R1 works fine and log the crashes.
      11.2.2022, 11:44:43	M915
      Driver 0.0: stall threshold 1, filter off, steps/sec 200 (4.0 mm/sec), coolstep threshold 234 (4.0 mm/sec), action on stall: none
      Driver 0.1: stall threshold 3, filter off, steps/sec 200 (40.0 mm/sec), coolstep threshold 234 (40.1 mm/sec), action on stall: log
      Driver 0.2: stall threshold 1, filter off, steps/sec 200 (72.7 mm/sec), coolstep threshold 234 (72.8 mm/sec), action on stall: none
      Driver 0.3: stall threshold 3, filter off, steps/sec 200 (40.0 mm/sec), coolstep threshold 234 (40.1 mm/sec), action on stall: log
      Driver 0.4: stall threshold 3, filter off, steps/sec 200 (40.0 mm/sec), coolstep threshold 234 (40.1 mm/sec), action on stall: log
      Driver 0.5: stall threshold 3, filter off, steps/sec 200 (40.0 mm/sec), coolstep threshold 234 (40.1 mm/sec), action on stall: log
      11.2.2022, 11:44:36	M915 V W X Y S3 R1
      But any configuration with R2 or R3 results in the defult state.
      11.2.2022, 11:46:29	M915
      Driver 0.1: stall threshold 3, filter off, steps/sec 200 (40.0 mm/sec), coolstep threshold 234 (40.1 mm/sec), action on stall: none
      Driver 0.3: stall threshold 3, filter off, steps/sec 200 (40.0 mm/sec), coolstep threshold 234 (40.1 mm/sec), action on stall: none
      Driver 0.4: stall threshold 3, filter off, steps/sec 200 (40.0 mm/sec), coolstep threshold 234 (40.1 mm/sec), action on stall: none
      Driver 0.5: stall threshold 3, filter off, steps/sec 200 (40.0 mm/sec), coolstep threshold 234 (40.1 mm/sec), action on stall: none
      11.2.2022, 11:46:25	M915 V W X Y S3 R3
      Any idea what might be wrong?
        jay_s_uk @vali3d
        @vali3d if running 3.4RC1
        The handling of driver stalls has changed. In the M915 command there is no longer a distinction between R2 and R3; both cause an event to be created when the driver stalls. To handle the event, RRF calls driver-stall.g passing the stalled local driver number in param.D and the CAN address of the board concerned in param.B. File rehome.g is no longer used. If file driver-stall.g is not found then the print is paused without running pause.g and the error is reported.
        vali3dundefined 1 Reply Last reply Reply Quote 0
        • vali3dundefined
          vali3d @jay_s_uk
          @jay_s_uk I should be able to set both modes, when testet it does not detect the crash at R2/3.
          jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @vali3d
            @vali3d are you getting any stalls at all?
            Are you explicitly setting the drivers as stealthchop? i.e. D3 in M569?
            vali3dundefined 2 Replies Last reply Reply Quote 0
            • vali3dundefined
              vali3d @jay_s_uk
              @jay_s_uk when I set a R1 it log them in the console
                dc42 administrators @vali3d
                @vali3d did you create the /sys/driver-stall.g file with appropriate contents to do what you want when a stall is detected?
                • vali3dundefined
                  vali3d @dc42
                  @dc42 I now created that file with some contents. Sadly that did not solve the Problem.
                  • vali3dundefined
                    vali3d @jay_s_uk
                    @jay_s_uk The M569 looks like this:
                    M569 P0.0 S0
                    M569 P0.1 S1
                    M569 P0.2 S0
                    M569 P0.3 S1
                    M569 P0.4 S1
                    M569 P0.5 S1
                    M569 P2.0 S1
                    M569 P2.1 S1
                    M569 P1.2 S1
                    M569 P2.2 S1
                    M584 V0.3 W0.4 X0.5 Y0.1 Z0.0 A0.2 R0 S0 E1.2:2.0:2.1:2.2
                      jay_s_uk @vali3d
                      @vali3d what board are you using?
                      • vali3dundefined
                        vali3d @jay_s_uk
                        @jay_s_uk MB6HC+2x EXP3HC (see https://forum.duet3d.com/topic/18329/duet-3-expansion-looses-connection)
                          @vali3d is it the drivers on the MB6HC that are not invoking the driver-stall.g file, or the ones on the 3HCs?
                          • vali3dundefined
                            vali3d @dc42
                            @dc42 all relevant drivers are on the MB6HC
                            • vali3dundefined
                              vali3d
                              I don´t think that there is a Problem with the file. The Problem is that the R3 cant be set. When I do M915 X S3 R3 and then M915 the configuration of the axis is on the default settig.
                                @vali3d I confirm this is a bug. I will fix it in the next RC, and I will probably make a test version available before then.
