    Paneldue 7i remains dark
    PanelDue
    319
    • EdTellerundefined
      EdTeller
      Ok, I'm following this great forum for a few months now. So yes, I pretty much searched the entire forum for clues on how to remedy this error.
      I am running a Duet2 wifi on an Ender 5+. First I bought a BTT E3 but then I decided to get the "real mccoy" because of R&D and credit where credit is due reasons.
      Back to topic: I was able to flash the Paneldue successfully including testing using my pc and bossa. (Tried PanelDue-5.0i-7.0i.bin as well as PanelDueFirmware-3.4.0-7.0i.bin)
      But after connecting it via the ribbon cable to socket CONN_SD on the Duet2 wifi the display remains dark. Dark, not white like backscreen light ON.
      As unlikely as it seems but I have no other guess than that the unit is somehow defective.
      I need the advice/ok from an admin in order to trigger an RMA process. But maybe that will be rendered obsolete because someone has an idea on how to bring the unit to life?
      Appreciate any help
      infiniteloopundefined 1 Reply Last reply Reply Quote 0
      • infiniteloopundefined
        infiniteloop @EdTeller
        @edteller What happens when you remove the ribbon cable and connect the PanelDue with the 4-wire cable (should have been included) as described here?
        EdTellerundefined 1 Reply Last reply Reply Quote 0
        • EdTellerundefined
          EdTeller @infiniteloop
          @infiniteloop tried that too. unfortunately same symptoms. just a dark display.
            What firmware are you running on the Duet?
            Do you have M575 P1 B57600 S1 in your config.g to enable to PanelDue? This is required in later versions of RRF3.
            Which firmware version specifically did you choose? Can you link the file?
            Did you follow the directions here?
            https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
            After the firmware update are you shown the touch calibration screen?
            • EdTellerundefined
              EdTeller @Phaedrux
              @phaedrux running rrf 3.1.1 on my duet; M575 P1 B57600 S1 is added in misc section of my config.g
              firmwares i uploaded and tested via bossa (got the instructions from https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue included https://github.com/Duet3D/PanelDueFirmware/releases/download/3.4.0/PanelDueFirmware-3.4.0-7.0i.bin and
              https://github.com/Duet3D/PanelDueFirmware/releases/download/1.24/PanelDue-5.0i-7.0i.bin
              The screen remains dark, no splash screen, no backlight, nothing.
                Phaedrux Moderator @EdTeller
                @edteller said in Paneldue 7i remains dark:
                Even when connected to the PC via USB?
                Can you get a close up well lit photo of the back of the panel?
                When and where did you purchase the PanelDue?
                • EdTellerundefined
                  EdTeller @Phaedrux
                  @phaedrux yes, even when connected to usb on the PC.
                  Here´s the back of the 7i panel.
                  The panel was purchased from Filafarm Germany on Jan 13.
                    Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                    • EdTellerundefined
                      EdTeller @Phaedrux
                      @phaedrux just wanted to report back: new paneldue arrived, attached -> works perfectly. thx again
