    Flsun Q5 leveling don't work, heating of the print bed two slow
    Duet Web Control
    • moby4realundefined
      moby4real
      My Flsun Q5 does
      1.) the leveling 2 centimeters over the print bed. Home, the leveling start and he do the steps, but not on the board, 2 centimeters over it.
      2.) the printing bed heat do slow, so I get an error!
      3.) the fans in the Web interface are there but they don't work.
      Please help me, I'm new in Delta printing. I Have from everything the newest version!
      Thank you so much!
      Kind regards
      moby4real
        Can you seen these?
        https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_linear_delta
        https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration
        The bed heating too slow error means you need to PID tune the heaters. Typically M303 H0 S60 but it will depend on which heater number your bed is and what temperature you wish to tune to.
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_tuning
        For more detailed help you'll need to provide us with more information including sending M122 and M98 P"config.g" in the gcode console and posting the results here. Also post your full config.g, config-override.g, homedelta.g.
        moby4realundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
          moby4real @Phaedrux
          @phaedrux Thank you so much, I will read all the links test it and it is not working I will posting the requested files! Thank you! moby4real
            moby4real @Phaedrux
            @phaedrux Screenshot Homedelta.g.png Screenshot config-override.g.png Screenshot config.g.png
            I do something wrong. Please help, thank you! Kindest regards Alexander
              Phaedrux Moderator @Phaedrux
              @phaedrux said in Flsun Q5 leveling don't work, heating of the print bed two slow:
              Still missing these.
              Where you able to PID tune your heaters?
              Where you able to do a delta calibration?
              moby4realundefined 1 Reply Last reply Reply Quote 0
                moby4real @Phaedrux
                @phaedrux
                The heating works, but the calibration not, I think the big problem is when I go town and calibrate the nozzle, I think I can not save where the nozzle is perfect. Also after I have done that it is not possible to probe the bed, he do that 2 cm over the bed! Please help, thank you so much! Kindest regards moby4real
                • Barracuda72undefined
                  Barracuda72
                  sometimes the first run on a delta is some try and error...your M665 in your config.overide shows that it never finished calibrating successful.
                  On my Delta most time was that the H Parameter is not nearly right..
                  For Example..u said H is 220mm but in real H is 240mm( as you said it stopped 20mm above bed. so the effector moves down and expect a probe triggering around the 220mm.. if it hnot happens, then it stop the probing. So make sure that your probe is working properly as described before...then change the H Parameter in your M665 and do it again..after the first successful G28 and savin it via M500 ou shouldnt have that problem again
