    Need Example for Fans to Turn On @ Certain Temps
    • Pickettundefined
      Pickett
      Like the title implies Im looking to make some certain fans connected to Out3/Out4 to be the hotend heatsink and nozzle fans however I wish for these to turn on when need be. I was also just thinking of making the heatsink fan for the hotend be turned on to 100 percent as soon as the power to the printer is turned on as to mitigate if not completely eliminate the possibility of heat creep issues. If anyone has some solid examples and has this down pat please lemme know please and thank you! From what Ive read in the documentation the fans are initiated by M950 and then M106.
      Honestly as far as the always on fans are concerned Ill most likely just wire them up to the PSU's dc output screws so as to mitigate any sort of overheating issues that could possibly arise for any sort of reasoning. It'd still be nice to at least know how to write it up correctly in the config.g file so anywho Ill leave it at that for now as far as what I wish to know for the fan dept of the Duet 3 Mini 5+.
      Thanks in Advance!!!!!
      -Pickett
        dc42 administrators @Pickett
        @pickett there is an example at https://docs.duet3d.com/User_manual/Connecting_hardware/Fans_connecting
