static charge
mostly when i touch the screen during printing, the duet runs in the routine to change the filament.
I think there is somehow static charge.
Has someone information about it?
Also if i resume after filament change it will not start at the last point. Always with an offset.
Any guess??
Thx
Dieter -
@icy_snake by "the screen" do you mean PanelDue, or a 12864 display, or something else?
@dc42 PanelDue7 inch with my modixbig 60 V3
@icy_snake is there a button on your PanelDue page to run that change filament routine? If so then the static discharge is probably being interpreted by the touch screen as touching that button.
@dc42 yes thats what i think is happen.
I will try after the print is ready some grounding to the printer an the display box.
I will inform you about my results.
thx
Dieter -
@icy_snake Good morning,
i connected all metal cases to ground.
Now it´s gone.Had to get ride of paint, so that there is an electrical connection.
thx
Dieter -
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
