    Hotend overshoots at beginning of print
    • bobzetelsundefined
      bobzetels
      I ran into an issue after setting up a duet 3 mini 5 for the first time.
      After the PID autotuning was done everything looked normal.
      When starting a print it heats up and starts, but after the purge line and skirt are printed an error occurs;
      "Error: Heater 0 fault: exceeded allowed temperature excursion: target 220.0°C actual 248.8°C
      The temperature started rising significantly (up to 250°c, setpoint was 200°c) and the printer made an emergency stop.
      How is this possible?
      Tried it on many files, all same problem.
      Heres my config.g file for mij setup
      *; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Feb 17 2022 19:48:12 GMT+0100 (Central European Standard Time)
      M550 P ; set printer name
      M665 R197.22 L351.4 B180 H400 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X-1.66 Y-0.18 Z0.00 ; put your endstop adjustments here, or let auto calibration find them
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M350 E256 I0 ; configure microstepping without interpolation
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z100.00 E7748.24 ; set steps per mm
      M566 X1000.00 Y1000.00 Z1000.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E10000.00 ; set maximum speeds (mm/min)
      M201 X8000.00 Y8000.00 Z8000.00 E8000.00 ; set accelerations (mm/s^2)
      M906 X900 Y900 Z900 E900 30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
      M574 Y2 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
      M574 Z2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in
      M558 P0 H5 F120 T9000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 R85 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H0 R0.324 K0.329:0.000 D4.99 E1.35 S1.00 B0
      M143 H0 S100 ; set temperature limit for heater 0 to 100C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 R2.959 K0.400:0.000 D7.43 E1.35 S1.00 B0 V23.9
      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
      M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
      M501
      droftartsundefined bobzetelsundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @bobzetels
        @bobzetels This is almost certainly a wiring issue. The jagged peaks and troughs in the thermistor readings show that the thermistor is failing, there's a loose connector, or it is picking up interference from something else. It's impossible for the real temperature to change that quickly.
          bobzetels @bobzetels
          @droftarts thanks for the respons.
          I changed to a brand new E3D thermistor for the Vulcano hotend i have installed, without any luck.
          In the end I restarted from a clean duet config using the RRF configurator and this solved the problem.
          I have no idea what the exact problem was, probably some fault in de config.
