    Corexy origin change...?
    • peirofundefined
      peirof
      I am used to a Delta printer, where the origin (X=0 and Y=0), was located in the center of the bed.
      With the new printer, the origin is a corner of the bed.
      I would like to change it, so I have been reading is possible, the biggest doubt I have if the gcode M557, where the grid is defined for the Mesh compensation, supports negative values.
      Someone uses, in a Cartesian or corexy printer, the center of the bed as the origin (x=0 a y=0)?
      What things o must have in account for define center of bed as origin?
        You can make it the center as well.
        https://docs.duet3d.com/en/User_manual/Tuning/Bed_origin
