    Easy question: Z-offset/trigger Height
    • westechundefined
      westech
      Thank for all the help. I got my BL touch and my mesh really nicely set. I would like a little more SQUASH, maybe bring the nozzle down 0.1mm.
      G31 P500 X-40 Y-12 Z2.08
      For the Z offset, I should reduce the number to bring the nozzle closer to the bed, or increase the number?
      Thanks.
      • rjenkinsgbundefined
        rjenkinsgb
        Reduce it, I believe?
        Robert J.
        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
        • fcwiltundefined
          fcwilt @westech
          @westech
          By Z offset to you mean the Z parameter to G31, the Z Trigger Height?
          If so remember that larger values move the nozzle closer to the bed.
          westechundefined 1 Reply Last reply Reply Quote 1
          • westechundefined
            westech @fcwilt
            @fcwilt Thanks, that's why I was confused. my Z is Z2.08. So if I change it to Z2.18 I will be .1mm closer to the bed.
            • fcwiltundefined
              fcwilt @westech
              @westech said in Easy question: Z-offset/trigger Height:
              Yes.
              When the probe triggers the logical Z position is set to the Z Trigger Height parameter value. That doesn't mean that logical position matches the physical position, though that is the goal.
              So if the Z Trigger Height parameter is 5, the logical Z position is set to 5 and the firmware "believes" that to move to Z = 0 it needs to move closer to the bed by 5mm. If after moving 5mm there is a gap between the tip of the nozzle and the bed that 5 value was too small. If before moving 5mm the tip of the nozzle touches the bed that 5 value was too large.
