    "M126 - valves not yet implemented" warning ??
    • Huguesundefined
      Hugues
      That's the first time i saw this in warning, the print continue without any issue but i just wonder if i didn't miss anything in the last firmware
        That message isn't new. The question is, why is your slicer generating M126 commands?
        • Huguesundefined
          Hugues
          It is the question… I ve use this profile lot of time before the new firmware and it didn't happen.
          M126 appear lot of time in my gcode generated by S3D and i don't know where it come from.
          • T3P3Tonyundefined
            T3P3Tony administrators
            Is there a setting where you have the gcode specified for a Makerbot printer?
            https://forum.simplify3d.com/viewtopic.php?f=9&t=857
            It looks like those are fan on fan off commands in makerbot's version of gcode
            www.duet3d.com
            • T3P3Tonyundefined
              Check within the Firmware configuration on S3D:
              www.duet3d.com
              • Huguesundefined
                Hugues
                Thanks for your reply ! I will check this. I will try to figure out why my makerbot profiles have been mixed with with core xy….
