    Nozzle move too late at the end of print
    Gcode meta commands
    159
    • Auré
      Auré last edited by
      I don't understand, when my printer reaches the end of the print, the nozzle stays on the last coordinate and the nozzle doesn't move.
      The petg melts and after a few moments the nozzle goes on the coordinate I specified when the print is finished.
      This makes a petg ball on my print on the last coordinate.
      Does anyone have an idea please?
      alankilian 1 Reply Last reply Reply Quote 0
      • alankilian
        alankilian @Auré last edited by
        @auré
        In my slicer Simplify3D, there's a place where I can enter GCODE that gets executed at the end of the print.
        I have this in there:
        M106 S0 ; turn off cooling fan
        M104 S0 ; turn off extruder
        M140 S0 ; turn off bed
        G28 ; home axes
        That shuts down everything and moved the printhead away from my print but does not disable the motors, so the printer doesn't drop the head onto the print.
        What slicer are you using and what does it have in its ending GCODE section?
        • Auré
          Auré last edited by Auré
          Yep!
          I use Cura my GCODE for the end of print is this:
          G91 ;Relative positioning
          G1 E-5 F2700 ;Retract a bit
          G1 E-5 Z1 F2400 ;Retract and raise Z
          M106 S0
          G90
          G1 X355 Y340 F3000 ;Wipe out
          M117 Fin d'impression
          • alankilian
            @auré
            OK, I think you are saying that line 2352 is your last printing move, and the time between that move and line 2359 where you move the head away from the print takes too long?
            Since line 2354 does a retract, I think you can skip line 2358 and the 'E' parameter on 2359 so maybe that will speed things up enough.
            • Auré
              Ok I try, I got to print a test.
              G1 Z1 F2400 ;Raise Z
              M106 S0
              G90
                dc42 administrators @Auré last edited by dc42
                @auré in your end GCode script you need to add M83 before the G1 E-5 line. This s because Cura sets the extrusion mode to absolute prior to running any user-provided scripts. This is totally stupid, but it's what the Cura devs implemented. What's probably happening is that the G1 E-5 line is retracting a lot of filament instead of 1mm, and that's what takes the time.
                Auré Phaedrux 2 Replies Last reply Reply Quote 3
                • Auré
                  Auré @dc42 last edited by
                  @dc42 said in Nozzle move too late at the end of print:
                  Thank you very much, as soon as I have solved my filament blockage in my extruder I will do some tests.
                  • Auré
                    Auré last edited by
                    Well, it seems okay with this:
                    M83
                    G1 E-1 F2700 ;Retract a bit
                    G1 E-1 Z1 F2400 ;Retract and raise Z
                    M106 S0
                    G90
                    Thank you very much both
                      Phaedrux Moderator @dc42 last edited by
                      You can still set Cura to use relative extrusion. It's an option under special moves section I believe and may be hidden by default.
                        dc42 administrators @Phaedrux last edited by
                        @phaedrux unless they changed it recently, even when you set relative extrusion, Cura emits a M82 command prior to any user-specified GCode scripts.
                          @dc42 I think it's just once at the start of the file. And if you've enabled relative extrusion the M83 will follow shortly after. As far as I know it doesn't switch back after that.
                            @phaedrux this is latest Cura:
                              @dc42 Yes you're right, it does insert a M82. I think I've never noticed an issue with that because I use firmware retraction, so my ending script just performs a simple retraction with G10 rather than a G1 E move.
                              Is that tooltip comment about slight deviations in the amount of deposited material actually accurate any longer?
                              • Auré
                                Auré last edited by
                                Hi
                                Thank you for your research!
