M291 S3 Z1 broke in RC2
M291 works in RC1 but stop working in RC2.
The babystepping buttons in M291 permanently greyed out.It is implemented in the custom macro.
M291 P"Please move the nozzle down to 0.10mm above the bed (use thickness gauge), then press OK to perform calibration." R"Nozzle Distance Calibration" S3 Z1 ; display message to jog nozzle down M292 P0 ; continue operation
@natthapol-v I can confirm that, actually I already pushed a fix to GitHub this morning.
PS: There are new preview builds available for SBC and standalone mode.
Good morning @chrishamm,
I have the same problem, I was not able to find the solution you mention, I downloaded the standalone mode from the link you uploaded, but the same thing happens.
I also looked on GitHub but I wasn't able to find anything (I don't handle GitHub well, it has to be said).
Thanks, best regards
@aitor Sorry, looks like the ZIP for standalone mode wasn't correctly updated. Please try again now.
@chrishamm i've updated to this and it only allows each Z movement button to be pressed once. e.g. I can jog by 0.5mm once but not again
@jay_s_uk That works for me both in SBC and standalone mode.
The same thing happened to me as @jay_s_uk, what I'm not sure is, if it stopped paying attention to me or if it just didn't refresh the positioning.
But if something strange has happened to me, in my case it was M291 Y1 that didn't react as I expected.
Best regards
I stop paying attention if I click more than once, confirmed, in case it helps or if that is the error, to be exact my M291 has active X1 Y1 in the same message.
Best regards
@chrishamm tried your fix --> some of the dial buttons are not functional all the time!
After homing Z the nozle is positioned at 5mm and the move down Z-0.05 works one time only and then the Z-0.05, Z-0.5, Z-5 are not working but Z-25 works
--> my bed to have a nice mark now!
undefined Phaedrux referenced this topic
