    ¶ Calibrate the Z probe trigger height Does not go
    Using Duet Controllers
    • dieterddundefined
      dieterdd
      So here I am again I want to calibrate my Z axis with the 3-d touch. I follow the instructions "https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing"
      "Calibrate the Z probe trigger height".
      Here is my last attempt:
      27.2.2022, 22:41:16: Connected to 192.168.178.77
      27.2.2022, 22:43:57: G30: Error: G30: Insufficient axes homed for bed probing
      27.2.2022, 22:44:42: M564 S0
      27.2.2022, 22:44:53: G30: Error: G30: Insufficient axes homed for bed probing
      27.2.2022, 22:46:46: M120
      G91
      G1 Z-5 F6000
      G90
      M121: Error: G0/G1: insufficient axes homed
      27.2.2022, 22:47:07: M564 S0 H0
      27.2.2022, 22:48:16: G92 Z0
      27.2.2022, 22:49:10: G30 S-1: Error: G30: Insufficient axes homed for bed probing
      Die config.g:
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Tue Jan 26 2021 16:38:54 GMT+0100 (Central European Standard Time)
      M550 P"DietersGrosserMKIV" ; set printer name
      ;M551 P"Macarena88" ; set password
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 0.0 goes forwards
      M569 P1 S1 ; physical drive 0.1 goes forwards
      M569 P2 S1 ; physical drive 0.2 goes forwards
      M569 P3 S0 ; physical drive 0.3 goes forwards
      M569 P4 S0 ; physical drive 0.3 goes forwards
      M569 P5 S0 ; physical drive 0.3 goes forwards
      M584 X5 Y1:2 Z3 E4 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E400 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E800.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z400.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
      M906 X1400 Y2500 Z2500 E1400 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-25 Y-72 Z0 S1 ; set axis minima
      M208 X10000 Y500 Z500 S0 ; set axis maxima
      M574 X1 S1 P"!io4.in" ; configure active-high endstop for low end on X via pin io0.in
      M574 Y1 S1 P"!io0.in" ; configure active-high endstop for low end on Y via pin io1.in
      M574 Z1 S1 P"!io3.in" ; configure active-high endstop for low end on Z via pin io2.in
      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
      M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-40 Y-2 Z0.0 ; set Z probe trigger value, offset and trigger height
      M557 X20:980 Y10:490 S120 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out2" T0 Q1 ; create heater output on out0 and map it to sensor 0 ; disable bang-bang mode for heater and set PWM limit
      M143 H0 S70 ; set temperature limit for heater 0 to 70C
      M140 P1 H0
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 Q1 ; create heater output on out1 and map it to sensor 1 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H1 S70 ; set temperature limit for heater 1 to 70C
      M140 P2 H1
      M308 S2 P"temp3" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
      M950 H2 C"out3" T2 Q500 ; create heater output on out1 and map it to sensor 1 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H2 S260 ; set temperature limit for heater 1 to 70C
      M307 H0 A200.8 C850.6 D2.0 S1.00 V24.0 B0
      M307 H1 A200.0 C850.0 D2.0 S1.00 V24.0 B0
      M307 H2 A491.0 C185.5.0 D4.9 S1.00 V24.0 B0
      M950 F0 C"out8" Q500 ; create fan 0 on pin out4 and set its frequency
      M950 F1 C"out7" Q500 ; create fan 1 on pin out5 and set its frequency ; set fan 1 value. Thermostatic control is turned on
      M106 P1 T45 S1.0 H2
      M563 P0 D0 H2 F0 ; define tool 0
      What am I doing wrong?
      3d drucken? - JA! Einen 3DDrucker bauen? - JA! Elektronik (Duet 3 6HC ) einstellen? - HILFE!!!
      3d printing? - YES! Build a 3D printer? - YES! Adjust electronics (Duet 3 6HC )? - HELP!!!
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @dieterdd
        @dieterdd
        Did you do this part?
        (From the dynamic test part:)
        • "If your printer is Cartesian or CoreXY, home X and Y. If it is a Delta, home all.
        (From the Test and Calibrate part:)
        • "Make sure the dynamic test is successful (Z probe stops when it senses the bed) before doing this."
        dieterddundefined 1 Reply Last reply Reply Quote 0
        • dieterddundefined
          dieterdd @alankilian
          Oh I guess where the error could be ... Thanks allankilian I have always either not homed or immediately all axes (just until the 3D Touch has triggered and retracted a piece) could that be the error?
          I'll try it out tomorrow, today I have withdrawn after 5 hours of testing, looking, G codes try to understand, research frustrated to a "Feierabend" beer from my printer construction zone.
          Thank You for the prompt answer!
          Dieter
          • dieterddundefined
            dieterdd
            Now it works. 😀
            I was confused at first, however, that the nozzle does not move to zero when referencing, but only when you give the command to "drill" 🙃 into the bed, then it stops dutifully at 0.
            Danke! Thank you!
