Solved Revo 5V fan on Duet3 mini
As per title can a Revo 5V fan be connected to a 5V pin on one of the IO Ports (I know you can on a 6HC but not to sure about the 3 Mini).
Probably a Question for DC42
TIA Doug
@dougal1957 you can take the 5v power from an IO port and then use the negative on the fan output to allow control.
undefined Dougal1957 has marked this topic as solved
