    Laser Job showing more than 100% 3.4RC2
    Beta Firmware
    463
      jay_s_uk
      @chrishamm
      Running a laser job on 3.4RC2. Currently showing as being 130% through the job
      here's my gcode file. change the file extension. I am using .gc as thats the output from lightburn
      Safe.txt
      • chrishammundefined
        chrishamm administrators @jay_s_uk
        @jay_s_uk On genuine Duet boards I cannot reproduce this in standalone or SBC mode with the file you provided. See my previous explanation what could cause this.
        Duet software engineer
          jay_s_uk @chrishamm
          @chrishamm I'm sorry, but i disagree that it doesn't affect duet boards.
          Yes, that original issue raised its head on a Fly-E3-Pro but I have since setup a bench test using a duet 3 mini and have got the same issue.
          The job ran to over 700% progress before finishing at 100%
          I was running this file
          tealight holder.txt
          here is my config
          ; Configuration file for SKR v1.4 (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.2.1-LPC on Tue Mar 02 2021 16:34:41 GMT+0100 (Mitteleuropäische Normalzeit)
          M555 P2                                        ; Marlin style responses
          G21                                            ; Set dimensions to millimetres
          G90                                            ; send absolute coordinates...
          M550 P"K40"                                    ; set printer name
          M552 S1 P0.0.0.0                                       ; enable network
          M586 P0 S1                                     ; enable HTTP
          M586 P1 S0                                     ; disable FTP
          M586 P2 S0                                     ; disable Telnet
          ; Set cartesian type and segment intervall one second and length 3mm --> needed to stop on pause immediatly!
          M669 K0 S1 T3
          M569 P0 S1 D3 V40                              ; physical drive 0 X goes backwards using default driver timings
          M569 P1 S0 D3 V40                              ; physical drive 1 Y goes backwards using default driver timings
          M569 P4 S1 D3 V40
          M584 X0 Y1 Z4                                    ; set drive mapping
          M350 X16 Y16 Z16 I1                            ; configure microstepping with interpolation
          M92 X157.50 Y157.50 Z400                    ; set steps per mm
          M566 X12500.00 Y12500.00                 ; set maximum instantaneous speed changes (mm/min)
          M203 X125000.00 Y125000.00               ; set maximum speeds (mm/min)
          M201 X12500.00 Y12500.00                   ; set accelerations (mm/s^2)
          M906 X0 Y0 Z0 I30                     ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                        ; Set idle timeout
          M208 X0 Y0 Z0 S1                               ; set axis minima
          M208 X310 Y220 Z40 S0                          ; set axis maxima
          M574 X1 S1 P"io0.in"                            ; configure active-low endstop for low end on X via pin xstop
          M574 Y2 S1 P"io1.in"                            ; configure active-low endstop for low end on Y via pin ystop
          ;############## Laser Settings #########################
          M452 C"out0" R255 S1 F5000 ; laser uses bed pin,  PWM frequency 5kHz
          and this is a screenshot of the object model during print
          • achrnundefined
            achrn
            @jay_s_uk When I saw this (on a Fly-E3-Pro) I determined that it's calculating on the basis of the previous file length. That is, it is calculating progress as (current file position)/(length of previously printed file). Does that match what you are seeing?
              jay_s_uk @achrn
              @achrn it could be, although I ran the 1st job I tried 3 times and didn't see anything. I then ran the 2nd job twice and didn't see anything. But the 3rd file went over straight away. And to reiterate for @chrishamm all of this further testing was with a duet 3 mini
              dc42undefined 1 Reply Last reply Reply Quote 1
                dc42 administrators @jay_s_uk
                @jay_s_uk @achrn are both of you running in SBC mode?
                  jay_s_uk @dc42
                  @dc42 I'm running standalone and if @achrn is using a fly-e3-pro, he will be too
                  dc42undefined achrnundefined 2 Replies Last reply Reply Quote 0
                    @jay_s_uk thanks, that tells me where to look.
                    • mrehorstdmdundefined
                      mrehorstdmd
                      I regularly see numbers like 850% complete (when the file is only partially finished) on DWC on my sand table that has no extruder. I think the first pattern file I run after booting the board shows a correct % complete value, but running a second file (or more) starts showing silly numbers.
                      I'm running Duet 2 WiFi, and last updated firmware about 4 months ago IRIC.
                      • achrnundefined
                        achrn @jay_s_uk
                        @jay_s_uk said in Laser Job showing more than 100% 3.4RC2:
                        Yes I am (both using a fly-e3-pro, and standalone).
                        Same as @mrehorstdmd, mine is a sand table so no extruder (and no extrusion commands in the gcode). On mine, the first pattern file I run stays at 0% progress (as if the preceding file was infinitely long).
                          dc42 administrators @mrehorstdmd
                          @mrehorstdmd does it occur when running a large GCode file, when you previously run a smaller one? Some users with this issue think it is using the file size from the previous job as the 100% mark.
                          mrehorstdmdundefined 1 Reply Last reply Reply Quote 0
                            mrehorstdmd @dc42
                            @dc42 That's entirely possible- I often run a relatively small erase pattern file followed by a much longer pattern file. I'll try it and see.
                              mrehorstdmd @mrehorstdmd
                              @dc42 I've been trying to make it misbehave for the last couple hours and it's not doing it now. The next time I see it I'll make a note of what I was doing.
                                @mrehorstdmd thanks for trying.
