    BL-touch randomly deploys
    • Zynch
      Zynch last edited by
      I'm having an issue with the bl-touch probe randomly deploying and then instantly retracting. Right now, I have to disconnect the probe before printing as it caused the probe to crash into the print before.
      I believe it starts doing it when the extruder heater is running.
      All of the cables in my printer are shielded (besides the first and last 2-3 cm), with the shields going to a ground point. Besides that the only notable thing I can think of is the cables are a bit on the longer side at about 5 m (the printer is my old cnc that I slapped an extruder on). The cable for the bl-touch is 5-wire 0.34 mm2.
      I was originally using a cheap clone, but replaced it with a genuine one. The only difference I could tell is that the clone had a more "distinct" movement, and the genuine one feels a bit sluggish.
      Also with the genuine I cannot run the bed mesh, as it will fail to deploy after a dozen or two points.
      Everything is running on a Duet3 MB 6HC (no sbc) with the following commands:
      Config:
      M950 S0 C"io7.out"                       ; create servo pin 0 for BLTouch
      M558 P9 C"^io7.in" H5 F120 T6000         ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X34 Y0 Z1.677                   ; set Z probe trigger value, offset and trigger height
      M557 X15:385 Y10:190 S20                 ; define mesh grid
      Deploy probe:
      M280 P0 S10
      Retract probe:
      M280 P0 S90
      I've been dealing with this for a while, and it's driving me crazy.
      jay_s_uk Hernicz 2 Replies Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @Zynch last edited by
        @zynch you may be better off using a toolboard to run everything off at the extruder, which would reduce the long cable runs
        • Hernicz
          Hernicz @Zynch last edited by
          @zynch BLTouch wire too close to exruder stepper wire.
          There are known knowns and known unknowns, things we know that we don't know. But there are also unknown unknowns.
          • Zynch
            @jay_s_uk said in BL-touch randomly deploys:
            At the moment, I'd rather try solving it without doing a bunch of changes and rewiring.
            @hernicz said in BL-touch randomly deploys:
            They do run next to each other in the cable chain, but there's no other practical way to route the wires. Which is the reason why I went with everything having it's own shielded cable.
            • mikeabuilder
              mikeabuilder last edited by
              I had this same problem, including the cable chain. And it was caused by crosstalk between the motor wires and the BL touch wiring. I proved it with a temporary bypass cable for the motor. with the bypass cable, the problem went away. My solution was to separate the cables some inside the cable chain. In my case I had two flat cables laying next to each other the whole run through the cable chain. Shoving them around a bit inside the chain to separate them a little solved the problem.
              Hernicz 1 Reply Last reply Reply Quote 1
              • Hernicz
                Hernicz @mikeabuilder last edited by
                @mikeabuilder I did the same. I've put every other cable between the two like a sandwich 😁
