Clear messages in WebUI
Is there a way to clear log messages from the WebUI? Everytime I issue a command from the interface I get a popup displaying messages from previous commands. For example, after starting a print I get 'File XXX.gcode selected for printing', than, after the print has finished, I move the bed down through the UI and get another popup, containing the same messages. If I then probe the bed with G30 (or something else, just as an example) I'll get a popup contianing the response from G30 and the text from the print before. But then it seems that there are just 3-5 lines that can be displayed, so I cannot see new messages after these. This started after the update to 1.19 (I'm now on the latest 1.20beta).
You can set a timeout for those messages in the UI settings. However, each popup should contain only the latest message, not older messages as well.
The timeout is set to 15s and this does work. But I keep getting 'old' messages, even in the G-Code Console, when I issue any command or get a message from the Duet:
16:07:59File bracket.gcode selected for printing
Warning: Macro file /macros/Layerscripts/PHA/0 not found.Resume-after-power-fail state saved
16:01:46File bracket.gcode selected for printing
16:01:45File bracket.gcode selected for printing
16:01:44File bracket.gcode selected for printing
These are the last three entries. I printed bracket.gcode yesterday. The warning is from my [c]M98[/c] in my slicers layer-change script. I just tried again, sending [c]M81[/c] through the G-Code Console and watched the Chrome-developer tools network tab.
[c]http://192.168.1.123/rr_reply[/c] gave me this in the 'Response'-Tab:File field_notes_pen_clips-PHA.gcode selected for printing
even though M81 should not trigger a response AFAIK
The obvious question is: why haven't you adjusted your grid definition so that all the coordinates are reachable by the Z probe?
Lazyness. I'm still trying out different mounts in differernt positions for the probe. When I find the perfect position I'll adjust the grid. But I don't think that this would cause the problem with the continous popups in the WebUI, because this also happens with other messages.
Edit: did you see the problem in the gif? Turning off the PSU results in the grid popup and the blue popup behind it containing all the messages, that are the same you can see before I click on the 'off' button.
I can't tell where the loop in your gif starts from, so I didn't understand what the problem was.
I am experiencing a similar error.
After pausing and stopping a print the following message appears over and over again:[c]Resume-after-power-fail state saved
Printing paused
Cancelled printing file 0:/gcodes/[…].gcode, print time was […]h […]m[/c]This message does gets printed over and over again with inconsistent delays.
Whenever I send a g-code command, the message will be appended to the g-code message in the console. For example:[c]M915 X S9 F0 R1
Printing paused
Cancelled printing file 0:/gcodes/[…].gcode, print time was […]h […]m[/c]The only way to stop this is turning the printer off and on again.
Everything is at v1.20
Are you connecting with different browsers? I had a script polling the duet for the current status. After I added this line to it the problem disappeared:
curl --connect-timeout 5 -s http://<ip-of-the-printer>/rr_disconnect > /dev/null</ip-of-the-printer>
No, there is no second browser connected.
Btw: I do not even have power fail saves enabled!
