    Data acquisition for Duet3 using OPC-UA
    • MegaGorilla
      MegaGorilla last edited by
      Duet3 supports data acquisition via html and Can communications. Is there a way to support data acquisition with OPC-UA in the future, or are there any plans to do so?
      My lab uses OPC-UA to manage sensors and some machines. I would like to integrate and manage the Duet information in OPC-UA.
      • T3P3Tony
        T3P3Tony administrators @MegaGorilla last edited by
        @megagorilla if you are using the Duet 3 in SBC mode then a plugin could be written for DSF to respond to OPC-UA requests or generate events/subscriptions.
        www.duet3d.com
        MegaGorilla 1 Reply Last reply Reply Quote 0
        • MegaGorilla
          MegaGorilla @T3P3Tony last edited by
          @t3p3tony Thank you for your response.
          So if I am using Duet3 in SBC mode, then
          1,Duet3 control function can be obtained by Raspberry Pi.
          2,If I create an OPC-UA plug-in for Linux and run it on Raspberry Pi, I can upload the Duet3 control functions to OPC-UA. (Export)
          3,If you create an OPC-UA plug-in for Linux and run it on Raspberry Pi, you can control Duet3 according to the function obtained by OPC-UA.
          Is my understanding correct?
          If I understand correctly, I would like to create an OPC-UA plugin for Duet3 in SBC mode.
          If you have detailed information on how to get Duet3 functions in SBC mode, please share it with me.
          Thank you in advance.
