    Duet 2 Maestro No Ethernet After Fault
    342
    • oracledude
      oracledude last edited by
      Started a print job through DWC, went and did other things, returned to see the hot end smacked the print, then somehow sheared itself off the heat sink. No clue how it could have failed that bad, but whatever.
      After installing a new hotend and heatsink, I noticed that the ethernet port is not active/lit. M552 shows enabled, IP address 0.0.0.0. This printer has been sitting in the same spot with DWC working just fine over the network for weeks now. I tried other functional cables on it, no luck. The cable that is plugged into it works fine elsewhere.
      Did I somehow fry the ethernet port via some over-stressed stepper motor?
        How far can you get working through this guide?
        https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
        • oracledude
          I'll give that doc a run through. The printer is responsive through the PanelDue though. Still upgrade the firmware?
            Do you see activity on the ethernet lights?
            Can you use M552 to set a static IP address and ping it?
            • oracledude
              No activity lights, tried multiple cables. Set the IP via "M552 S1 P192.168.1.50" and I can't ping it, but on the PanelDue the M552 says network is enabled and the ip is the same.
              • oracledude
                Here's something interesting I discovered while serial debugging....
                Anything in ***** is my comment
                With mains power...
                M115
                FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.4.0rc2 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2022-02-22 17:06:07
                ok
                M552
                Network is enabled, configured IP address: 192.168.1.50, actual IP address: 192.168.1.50
                ok
                M552 S0
                ***** App hung here for a second*****
                ***** USB dropped and reconnected *****
                M552
                M552
                M552
                ***** I had to disconnect and reconnect terminal to get any response*****
                M552 S1
                ok
                M552
                ok
                when it's powered just by USB...
                M115
                ok
                M552
                ok
                M552 S0
                M552   ***** No response *****
                M552
                M552 S1
                ***** terminal disconnects here, but allows reconnection ******
                M115
                ok
                M552
                ok
                • oracledude
                  Think I might be hosed and will need to use DSF with a Pi?
                    Can you post some photos of the board? Is there any visible damage?
                    Especially around the ethernet port?
                    @oracledude said in Duet 2 Maestro No Ethernet After Fault:
                    That's not really an option with a Maestro. Duet 3 only.
                    • oracledude
                      This post is deleted!
                      • oracledude
                          dc42 administrators @oracledude last edited by dc42
                          @oracledude most likely the W5500 Ethernet chip has failed. When there is a transient that causes the 3.3V rail to exceed its normal voltage, the first components to fail are usually the SD card and the W5500 chip.
                          The W5500 chip can be replaced, but it's not easy without the right equipment.
                          oracledude 1 Reply Last reply Reply Quote 0
                          • oracledude
                            oracledude @dc42 last edited by
                            @dc42 No big deal, I've worked with smaller SMD packages before. WizNet W5500, 48LQFP. $4 at DigiKey. Beats having to buy another board, even if the Duet 3 Mini 5 looks really good.
                            • oracledude
                              The IC should be here in the next few days. I'll let you know how it goes.
                              • oracledude
                                So i soldered in a new W5500. Boots up fine, panelDue communicates fine with the board, but ethernet still is non-functional.
                                m552 s0
                                Network stopped<LF>ok<LF>
                                m552 s1
                                ok
                                m552
                                Network is enabled, configured IP address: 192.168.1.50, actual IP address: 192.168.1.50<LF>ok<LF>
                                m115
                                ok
                                There is no visible damage to anything on the board. I looked at it under magnification and nothing was burnt, cracked, or popped.
                                It's been sitting around for 4+ years with very sporadic use. Could just be "old". Maybe the head crash pushed some amps into the Atmel? I'm at a loss at this point.
                                  That's too bad. Maybe @dc42 has some other ideas.
                                    @oracledude if you set the M552 IP address to 0.0.0.0 does it succeed in acquiring an IP address via DHCP?
                                    • oracledude
                                      Nope. No ethernet lights on the card or the network port.
                                      Network is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
                                      • oracledude
                                        @dc42 - any ideas? or just toast?
