    EN+ EN- they are important for accelerations and decelerations
    • paolozampini1973undefined
      paolozampini1973
      @dc42 Good morning kindly I wanted to know these pins EN + EN- if they are disconnected for the accelerations and decelerations if they lead has a pitch loss problem and I wanted to know with external drivers DM860H NEMA17 17HS19-2004S1) thanks
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @paolozampini1973
        @paolozampini1973
        THE DATASHEET for your stepper motor driver says:
        Enable signal: This signal is used for enabling/disabling the driver.
        High level for enabling the driver and low level for disabling the driver.
        Usually left UNCONNECTED (ENABLED).
        You do not need to connect any wires from your Duet to these connections.
        The stepper motor drivers will be enabled all the time and your stepper motors will have some torque holding them stopped when you are not moving them from the Duet.
        • dc42undefined dc42 referenced this topic
        • droftartsundefined droftarts moved this topic from Documentation
