    Solved duet3 mb6hc accelerometer wiring?
    • fractalengineer
      fractalengineer last edited by
      I'm just about ready to wire a LIS3DSH to my MB6HC but I've noticed a discrepancy in the guide;
      It calls to connect CS to SPI.CS4 but there doesn't appear to be such pin on the board doc; it goes from CS0 to CS3
      How are the pins actually assigned on the MB6HC?
      Thanks!
      Railcore II ZL
      rjenkinsgb dc42 2 Replies Last reply Reply Quote 0
      • rjenkinsgb
        rjenkinsgb @fractalengineer last edited by
        @fractalengineer
        This is what works for me, with the same gear:
        ; Accelerometer
        M955 P0 C"spi.cs3+spi.cs2"
        Use the pins with those names on the temperature daughterboard connector.
        Robert J.
        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
        fractalengineer 1 Reply Last reply Reply Quote 1
          dc42 administrators @fractalengineer last edited by
          @fractalengineer the new documentation at https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_Accelerometer is correct.
          • fractalengineer
            fractalengineer @rjenkinsgb last edited by
            @rjenkinsgb Yep that worked; should have read further I would have found my answer in the doc hehe
            Thank you!
            Railcore II ZL
            • Topic has been marked as a question  dc42 dc42
            • Topic has been marked as solved  dc42 dc42
