    Web config tool for Mini 5+ is missing the drive 5 and 6
    Config Tool
    • tapirathundefined
      tapirath
      I might be doing something wrong but it doesn't allow me to add more than 5 steppers whereas this board supports 7 steppers.
      Any ideas?
        jay_s_uk @tapirath
        @chrishamm it appears the 2 driver addon for the Mini 5+ (both wifi and ethernet) is missing in the config tool
        • Phaedruxundefined Phaedrux moved this topic from Using Duet Controllers
          Yes that's right, the 2 driver expansion board isn't an option in the config tool at the moment, but the config tool will be getting an update soon that should fix that.
          In the meantime, you'll need to manually add the driver and axis commands to config.g.
          • tapirathundefined
            tapirath
            @Phaedrux I also can't select out5 or out6 for the heaters. Since using an SSR doesn't require high current we should be also able to select those outs right?
              Phaedrux Moderator @tapirath
              The config tool is meant to get going with the most basic configurations. As out5 and out6 cannot be used as a heater directly, they aren't listed. In the updated config tool perhaps it will be possible to indicate that an SSR will be used and allow the low current outputs to be selectable. As of right now, that would need to be manually defined in config.g.
